Question about Dell 922 All-In-One InkJet Printer
Hi, My dell aio 922 printer broke. So I bought another one same model(but used). I unpu=lugged the broken one & plugged in the other one. And it tells me its not communicating with my computer. What do I need to do?
  • 1 more comment
  • schlegelc Jul 16, 2010
    I tried doing what the other person told me & there was nothing there for me to inuninstall or install
    I tried a # of things
  • schlegelc Jul 18, 2010
    Can sone help me with my printer problem.
    Thanks,
    Charles
  • Dell Master
  • 4,737 Answers
Was it working when you bought it? Or did you test it before you brought it to your place? If so, first uninstall the drivers and re-install it after restarting your computer. Install the printer's software first (if it comes with a cd package) and connect the printer only when you are asked. Make sure you are using a good/working usb cable. (if there's only the driver with no additional software for your printer, then first connect the printer and follow the onscreen inscreen instructions to install, let me know if you can't do this.)
If this doesn't solve your problem, let me know withe the Operating system installed on your computer and system configuration. I'll help you fix this.
Good luck.
Thanks for using FixYa.
Posted on Jul 18, 2010
  • 4 more comments
    Yes it was working before I connected it to my pc(I can still make b&w & color copies). Even though it was used. I figured because it was the same make & model as the one that broke(scanner glass broke on the old one, but it still recognized it when it was connected (it still coud communicate with it). All I had to do was just connect it with the usb & power cords & it would work. Simple! Why not?
    So I did what you said again & it still dosen't communicate with my pc. Hope you can look at all the things I tried & responded to alresdy I spent over a total of 12+ hours trying to get this to work.
    Thanks
  • schlegelc Jul 19, 2010
    Hi Again,
    I have windows xp (service pack 3) 2007. I'm about ready to give up hopefully someting has got to work. rsvp.
    Thanks,
    Charles
  • schlegelc Jul 20, 2010
    I'm still waiting for a response.
    Thanks,
    Charlie
  • Lebanon Raingam
    Lebanon Raingam Jul 20, 2010
    I am sorry for the delay. If there's no problem powering it on, replace the usb cable and connect it on another port. Keep trying and don't connect any usb device on the system. If no positive outcome, please try it on another system and let me know the outcome.
    Awaiting.
    Sorry, no good. Doesn't work.
  • Lebanon Raingam
    Lebanon Raingam Jul 21, 2010
    I am sorry to hear that. Thanks that you've taken the trouble to test and made attempts upto that point. Now I can assure that, there must be problem with the printer's usb port or printer's usb module (who knows, this could have happened recently). You have two options, first replace the usb port, (you'll need a set of screwdrivers, a new usb port and soldering materials to do this) and check whether this helps or not. If this doesn't either help, your final destination is the Service Center where they will test the usb module (usb controller IC), I don't think there's replacement available for this and I have never done this before since we can never able to obtain a new module. Anyway, once they check it, they'll confirm you whether it can be repaired or it can't be repaired.
    I can only wish you good luck.
  • 493 Answers
What is your operating system?
Did you test its copy function on the printer itself to see it works or not?
- If it is Windows, complete windows updates such as .net framework and Java software.
- Disconnect your printer.
- Then download and run this patch/upgrade file from this link. When it prompts you to restart the PC do it.
- Download and install the compatible printer drivers for your operating system ( XP, Vista 64-bit, Vista 32-bit, others)
When prompted to connect your printer connect and power on.
Hope this helps.
Waiting your comments.
Posted on Jul 16, 2010
  • 11 more comments
  • Ibrahim OKTAY
    Ibrahim OKTAY Jul 16, 2010
    And please check the USB cable connections.
    sorry it took so long but my os is xp2000. Yes I'm able to make copies (color & b&w). I down load the following from your list net.framework, java,disconnected printer, patch/thislink. inslalled everything even in the zip files.Thought I had it when it asked me to print a test page alignment, but came up no communication with computer; check firewall settings. I just drew a blank. I've been doing this fora little over 8+ hours. & its getting more & more frustrating.
    any other suggestions?
  • Ibrahim OKTAY
    Hi again,
    You didn't mention about the error message related to firewall in your question. So check the followings.
    If you have antivirus programs working on your PC it may cause this problem. If you have MacAfee, allow the Windows file sharing in the MacAfee setup if it is not done.
    You can disable all antivirus and security software then test your printer.
    Try to disable windows firewall and then test your printer. If it works then you need to setup the firewall.
    I have norton antivirus. Tried what you suggested & it still didn't work. No communication
    Any other suggestions
  • Ibrahim OKTAY
    You said that you checked anti-virus software.
    Would you please check Windows firewall and the other procedures as described in this link for Windows XP operating system?
    Tried what you said & it still says no communication between the printer & the computer
  • Ibrahim OKTAY
    Hi again,
    You may check in the Printer's Properties to ensure the port is correct. It should be "Dell USB" or "USB Virtual Port" etc. something similar.
    Does it print a Test Page from the Print Properties?
  • Ibrahim OKTAY
    If it doesn't print test pages, unplug the power cable from the back of the printer, push and hold the power button on the printer for about 15 seconds to clear the internal memory, then plug it back in and try to print test page.
    I'm back again I was gone for a few days. I spent over 10+ hours on this comuter/printer problem. I tried the last few thing about the test page plug & unpluged.No good.Also before that I checked the port connection & thats ok. Any other suggestions.
    Is any one there to respond to my message I recently sent.
    Thanks,
    Charles
  • Ibrahim OKTAY
    Ibrahim OKTAY Jul 19, 2010
    Hi again,
    First try another port of your PC.
    Can you connect and install another printer to your PC and test it to see that your PC (USB port and operating system) has no problem. If it works then we can say that your second hand printer or its port or its cable has problem.
    President:
  • 567 Answers
Hi thanks for asking, you should uninstall and reinstall the drivers for the printer,make sure the connections are okay and then you can try to print a test page. please feel free to ask me any questions about this problem. thank you
Posted on Jul 15, 2010
  • 14 more comments
  • schlegelc Jul 15, 2010
    How doI uninstall & reinstall the drivers
  • Hilton Bristol Jul 15, 2010
    Click on the start button, go to control panel,click on add or remove programs and look for the dell printer drivers click on it once then click remove and follow the steps.
    how do I unistall & reinstall the drivers
    To uninstall the drivers, click on the start button, go to control panel,click on add or remove programs and look for the dell printer drivers click on it once then click remove and follow the steps.
    there is nothing there for me to remove or insall with drivers that pertain to the dell printer
    what's next
    i was telling you to remove them and install them again
    I realize that,but there is nothing there to in uninstall or install !
    All you need to click on it once and you will see the word remove will appear just click on remove and follow the steps
    I'm telling you again there is no drivers to uninstall or install or change.
  • Hilton Bristol Jul 16, 2010
    Therefore your computer does not have the drivers install for the printer you should go to www.dell.com and choose your model of printer and download the drivers.
    I tried that 3 differnt times & while it was donwloading it mentioned somtime about microsoft may not recognize it & in 2 little boxes below it said continue or cancel I did both ways & it still says I need the drivers to communicate.
    Even though it say microsoft does not recognize the drivers you should still proceed to install it
    I had told that you do not have any printer drivers install on the computer you need to install the drivers for the printer,please go to www.dell.com and download the drivers.
  • Hilton Bristol Jul 18, 2010
    Hi in order for your problem to be solve you need to download and install the drivers for the printer before it can communicate with your computer,please go to http://support.dell.com/support/download...
    You printer do not seem to have the drivers install
Problems with existing printer.
Not at the current time. Dell only have a Vista 32bit, Win XP and Win 2000 driver available. As there is no specific Win 7 driver the advice is to use the Vista 32bit driver until and if one is released.
You can download the latest VISAT 32 bit drivers from DELL at the following link
http://support.euro.dell.com/support/downloads/driverslist.aspx?os=WLH&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=PRN_ALL_A922&hidos=WW1&hidlang=en&TabIndex=&scanSupported=True&scanConsent=False
Nov 06, 2009 | Dell 922 All-In-One InkJet Printer
I want to have AIO software and scanning ability using Vista with my Dell 922
open link and download driver ......
http://supportapj.dell.com/support/downloads/driverslist.aspx?c=in&l=en&s=gen&ServiceTag=&SystemID=PRN_ALL_A922&os=WW1&osl=en&catid=&impid=
Sep 18, 2009 | Dell 922 All-In-One InkJet Printer
My Dell 922 AIO prints but cannot scan. There is
Make sure that your printer is set as default printer in the Control Panel.
Sep 14, 2009 | Dell 922 All-In-One InkJet Printer
I recently got a new Dell computer and kept my Dell AIO 922 printer, but now the icon is lost, I cannot scan. However, I can print, but that is about it.
Do you still have the Dell AIO 922 Drivers and Utilities CD? If so, you can reinstall it on your new Dell PC with the Drivers and Utilities CD. Although you are able to see this printer in your list, the other components are missing such as the scan and fax options. If you have already reinstalled it using the CD, you should see the All In One Center under the Start Menu/ All Programs/Dell Printers/Dell AIO Printer 922 and the All In One Center should be showing there. You can right click on the All in One Center and select "send to" and choose desktop to create a shortcut or icon on your desktop. Your options for scanning and faxing should be showing here. Hope that helps!
Aug 31, 2009 | Dell 922 All-In-One InkJet Printer
Have just bought a mac is a dell printer AIO 922 compatable?
dell printers are manufactured by HP, and HP has a reputation of not working with mac...my solution is to buy a PC
Jun 18, 2009 | Dell 922 All-In-One InkJet Printer
Dell AIO 922 printer not seeing the color cardridge
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" Click here and slecet the operating system and download the drive
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Jun 17, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 printer will not print on the lines of lables
My dell photo aio 922 says there a communication problem and i try to print i do everything it tells me to do for exaple recconect the usb restart computer and try and take the printer plug out but still i am haveing the same problem
Dec 08, 2008 | Dell 922 All-In-One InkJet Printer
Aio 922 power light constantly blinks on and off, will not turn on/off or communicate with computer.
Try to unplug the power cable as well as the USB cable of your printer for few minutes. Then plug it back in, check the lights again.
Oct 09, 2008 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
59 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
