Question about Staples Office Equipment & Supplies
Paper shredder jam was cleared, now making a whining noise.
My Staples SLP-710SH Paper Shredder jammed and was cleared out. It is now making a high pitched whining noise and is not accepting paper at all. Is there a reset button? How can I get it to shred again?
2 Suggested Answers
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
I'm looking for a manual for an spl tmc162a staples shredder
The bin has not been inserted sufficiently to close the interlock switch.
Feb 04, 2018 | Staples Office Equipment & Supplies
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
My shredder won't power on. It is not overheated.
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Aug 11, 2013 | Staples Cross-Cut Shredders; 10 Sheet
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
May 09, 2010 | Staples SPL1050LBRX (CrossCut) Shredder
Staples spl-710sh paper shredder stopped shredding
Jun 16, 2009 | Office Equipment & Supplies
290 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
