Question about Bowflex Series 3 Treadmill Msrp 129999
Our Bowflex Series 3 Treadmill will not start up. The power is there because the red light at the bottom front is on. the start button does nothing. When I pull of the safety plug, it reads version and either Sr3 or 5r3. when I removed the cover, I noticed that there is only one red light on and the one next to it on the mother board which was flashing previously, is now out. what can I do?
blueextc3221
  • 15935 Answers
SOURCE: Err LS on Bowflex Treadmill
The machine needs to be re-callibrated. L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
The instruction book doesn't mention calibration. be sure to not callibrate in metrics, however (there's no way to easily tell the difference - you have to ask) or you'll be strolling like a walk in the park at 5 "mph".
Thanks for using FixY - a FixYa rating is appreciated!!
Posted on Feb 21, 2009
  • 64 Answers
SOURCE: I have a Nautilus Bowflex 5 series treadmill.
I will have to check the error code but sounds like a heat problem. When you get too much friction between the walk belt and the deck it builds a lot of heat which creates more drag on the motor. This causes the motor to overheat which in turn usually shuts the machine off. You can let it cool and go back exercising until the cycle repeats. If this sounds like your issue, try lubricating the walking belt. If it's not in bad shape it should make a difference. The machine should run longer. 10-15 is pretty quick though so it make take a couple of application of lubricant. The belt may need replacing if the need for lubricant becomes too regular.
Posted on Nov 17, 2009
SOURCE: bowflex treadmill series 7 saying safe out
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
Posted on Dec 21, 2009
SOURCE: bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Posted on Jan 12, 2010
AJIN G
  • 6694 Answers
SOURCE: I recently purchased a Bowflex
hi,
i think ur tread mills motor controlling circuit have some problem. may be its motor controlling igbt faulty. check it. proper care should be taken will working in tread mill. all the circuits are live . chances for electric shock. do any thing only after removing the power.
ok
Posted on Dec 27, 2010
How to recalibrate a bowflex series 3 treadmill
Plug power cord into wall outlet and turn on power switch. 2. Stand on the side foot support platforms or rubber floor mat. DO NOT STAND ON THE WALKING BELTS. 3. Insert the Safety Key. Note: The Bowflex if the Safety Key is not fully inserted into the safety keyhole. 4. Press and hold hold "ENTER" and "POWER" for 3 seconds while the Console is dormant. The word "CAL" shows on the display. 5. Press "START". This enables display of maximum speed (with unit of measure) and maximum incline. 6. Verify correct units of measure (English imperial/ metric). Press "START" to change from one type to another. Press "ENTER" one time to set the measurement unit. 7. Press "START". 8. Press "POWER" again to save and exit, once calibration is complete
Oct 21, 2016 | Bowflex Exercise & Fitness
Machine shuts off- says LS
follow this steps and fix it. God bless you
Plug Treadmill into wall outlet and press
START.
Display lights up; TREADBELT DOES NOT MOVE "L5 / LS ERROR"
Is red SERIAL lamp on the motor control
board lit?
Is the yellow RLC lamp on the motor
control board lit?
1. Unplug the treadmill from its
2. Wl alk on the belt manually. (push belt)
3. Does the yellow MOTOR lamp light while pushing?
Is yellow MOTOR lamp on the motor
control board lit?
1. Loose wire connection to motor, capacitor, or choke.
2. Loose brush holder screw on motor. (Check Both)
3. Failed drive motor. Part # 70014 (110V), 70125 (220V)
NO
YES
NO
YES
5.1
5.2
5.3
5.4
5.5
NO
1. Check wiring harness connection between
upper and lower board. Part # 70083
2. Replace display board. Part # 70076
YES
Enter Open Loop Speed mode:
WARNING: NEVER STAND ON THE TREADBELT IN THIS MODE.
1. Turn off the treadmill.
2. Press FAST and START simultaneously and release both buttons once the display lights up.
3. Hold the fast button until the display reads 99.
Short in capacitor, motor, or motor
control board.
NO
Turn treadmill off. Disconnect drive motor wires from lower control board (Mtr + and Mtr -)
terminals. Power up in OLS mode (FAST & START). Bring displayed speed up to 99.
Measure across the Mtr + and Mtr - terminals with your voltmeter (DCVolts). You should
measure at least 90 vdc on a 110V treadmill and 180 vdc on a 220V treadmill.
If you are not getting dc volts out of the lower board, replace it.
If you are measuring the proper dc voltage out, replace the drive motor.
Sep 19, 2013 | Bowflex Exercise & Fitness
Bowflex series 7 treadmill Calibration fail. Next indicated action?
It looks like the main circuit board is damaged and needs to be replaced unless there are separate modules in it.
Jan 22, 2013 | Bowflex Series 7 Treadmill Folding Pro...
Bowflex Series 7 Treadmill motor problem
1) test the power cord for open, break
2) see if there some animal, bid the some wires internal, and get touch with the chassins provoking the short in the machine.
3) replace the blown fuse inside, see the block
4) test the main switch for open or defective.
5) unplugg the machine and see if there c.breaker or fuse are tripp? if does the problem is the c.breaker from your home
6) do NOT use extension cord, and buy some detector spikes, glitch,transient.
God bless you
Jun 26, 2012 | Bowflex Series 7 Treadmill Msrp 199999
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
May 05, 2011 | Bowflex Treadmill Series 7
Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Dec 30, 2009 | Exercise & Fitness
Bowflex treadmill series 7 saying safe out
Jun 14, 2009 | Bowflex Treadmill Series 7
Bowflex series 3 stops after 10 min
To much electrical draw on motor control board
Lubricate, lubricate, lubricate
Jan 26, 2009 | Bowflex Treadmill Series 7
Bowflex Series 3 Treadmill  Msrp 129999 Logo
105 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
