Question about Garmin Nuvi 660 GPS Receiver
I've been using after market chargers in car and on ac. They worked fine for a long time. Now, my Garmin NUVI 660 seems to turn off (goes into "charge mode" or something) when I plug my car charger into the slot on the side of the Garmin (not the connection built into the windshield mount.) I took it back to Best Buy (where I bought it). They said "It has a short. Just buy another one.") Do I need to order a replacement charger from Garmin, if available, or is the thing washed up. It seems to work fine when just on batter power, so I can charge it from my computer or an ac charger. It's just when I try to use it with the car charger that it goes out. Of course, I can use if briefly on the battery, but it turns off in about a minute or two when on the battery. Thanks, sam424
  • Garmin Master
  • 2,130 Answers
Yes, many aftermarket chargers are not wired the same as a Garmin charger and will cause your Nuvi to think it's connected to a PC. What happened to the original charger that plugged into the cradle (the part your Nuvi snaps into?)
Please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Posted on Jul 21, 2010
4 Suggested Answers
SOURCE: Garmin Nuvi 660
if i go to europe,will i be able to get eurpe maps
Posted on May 30, 2008
Foxy_sister0
SOURCE: how do i unlock garmin nuvi 660 ? thanks
how do i unlock the gps
Posted on Aug 03, 2009
sharcnet
  • 2130 Answers
SOURCE: Nuvi 660 GPS Receiver: The screen froze on the garmin nuvi 660...when i t...
Please see this link for repair info:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on May 20, 2010
Will a garmin gtm 20 charger work with a garmin nuvi 660 gps
Yes! The GTM-20 is a charger with a built-in traffic receiver. The charger plugs into the cradle for the Nuvi 660 and then the Nuvi 660 snaps into the cradle.
However to receive traffic with the GTM-20, you will need to purchase a subscription, either yearly or lifetime. The traffic receiver receives traffic information from FM radio broadcast stations, which broadcast traffic data.
Feb 23, 2014 | Garmin GPS
I've borrowed a friend's Garmin for a trip and when I use the car charger, it doesn't display anything. Once I disconnect, it becomes visible again. I'm going on a long trip and worry. ...
Assuming there is power at the cigarette lighter jack - turn the Nuvi off - then connect the charger. It should display charging battery or charging complete.
If nothing - does it charge with the wall charger? If so check the fuse in the car charger - it's usually in the tip of the charger which can be turned to get the fuse out.
Jul 05, 2011 | Garmin Nuvi 660 GPS Receiver
Garmin 260w: After someone laid a heavy book bag on the Garmin the plug was bend where it goes into the unit. After that the unit will not turn on and blows the fuse ever time I hook another charger up to...
Either buy a new one or return to Garmin for repair.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Go here for repair: http://www8.garmin.com/support/outofwarranty.html
Nov 25, 2009 | Garmin Nuvi 660 GPS Receiver
660 nuvi charges fine with AC charger, but not with 12v car charg
The real question is this:
1. When you plug the Nuvi onto the cradle, do you see a yellow lightning bolt appear over the battery icon at the main menu?
Compare it with the AC charger. If you don't see the lightning bolt, then you either have (2) problems:
1. There is a problem with the car charger not feeding power to the Nuvi.
2. There is a problem with the rear cradle socket on the Nuvi.
I have fixed both problems before. More info can be found here:
- Jim
Oct 04, 2009 | Garmin Nuvi 660 GPS Receiver
My 6 month old Nuvi 760 turns on, but no signal
It is entirely possible you need a new battery. Use and abuse shortens the battery life. Starting the engine while GPS connected or overcharging on AC or PC.
If it fails to acquire on full charge or replaced battery then it has a damaged chip from the usage i stated above. Not warrantble either.
Jun 30, 2009 | Garmin Nuvi 660 GPS Receiver
How do I turn off our garmin nuvi?
Reset button behind the Antenna, press this in for a few seconds.
Use the Web-updater at Garmin, to update it too,
Jack it to a PC and run the update,
If still playing up, Use the Firmware update at Garmin for it,
(( google Garmin 660 software updates ))
Should be good then
Regards
Richard.
May 18, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi does turn on when connected to power in car
Hi
I had the same problem. My Nuvi 350 did not power up for a couple of days. I suspected moisture to be the culprit. So I took my wife's hair dryer and blew hot air(in the intermediate setting) into the SD card slot in the GPS for a couple of minutes. Take care not to overheat the GPS or Screen.
Pronto my GPS powered up without any issues.
Hope this helps
Oct 24, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660
Owners can select a pin code to use which locks the unit preventing use by theives. Sat Nav theft is a big market. The unit needs to be sent to Garmin who will verify you are the registered owner and unlock it for you. If you bought at a market is there a good chance it may have been stolen?
Sep 18, 2008 | Garmin Nuvi 660 GPS Receiver
When I plug my Garmin Nuvi 660 in to recharge the battery, I can't use it while it's being charged. Is that normal. (Seems kinda dumb.)
Which charger are you using? The USB? AC charger? Car charger? It should work fine when using the AC or car charger. Using the USB places it in USB mode for programming.
Sep 16, 2008 | Garmin GPS
Stop transfering voice from Sony Ericson P910i and Garmin Nuvi 660
Can you update the firmware on your unit
my k800i sony phone had a problem synchronising and would freeze, then one day the nuvi 660 updated the firmware by itself and has been fine since, only problem being the volume, a bit low when trying to contest with large diesel engine, onboard speaker keen to distort over 80% volume
Feb 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
314 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
