Question about Philco (R) Retro Nostalgia Music CD&Turntable Record Player with AM/FM Radio Shelf System
The turntable will not turn even after we have moved the arm has been moved to the right and clicks.
Crosley turn table is not spinning. Tried replacing belt and moving cue lever to right then left. Think it might be the arm or cue lever. Does anyone have an idea what the problem is or a solution?
Since it is new, you should probably return for refund or exchange.
My guess would be it is the micro switch controlled by the arm.
Make sure the power is turned on and the unit's function selection is set on PHONO and then gently move the tone arm to the right until you hear a "click". Remove any cassettes that might be in the cassette player. Lift the tone arm and carry it over to the beginning of the record.
TroubleShooting
Jan 27, 2016 | Crosley CR49 Portable Traveler 3-Speed...
Sears model 400.91741 turntable doesn't turn under power. It will rotate when i turn it by hand and the unit is getting power. To start spinning, the instructions say to move the needle arm to the right...
Turntables usually are spun by a 'rubber band' type of arrangement. Look under the platter for a broken belt that would attach to a drive motor and then around the platter. I would contact the manufacturer for the correct belt. You know records are making a huge comeback.
Jan 18, 2015 | Audio Players & Recorders
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Detrola record player wont spin, even after moving arm to far right.
I suggest you lift up the turntable matt and see if you can see a belt, which has either broke or come off. You might need a new belt!
Mar 22, 2013 | Audio Players & Recorders
The turntable on my philco cd cassette and turntable unit does not turn. how to i access the belt, etc. to see whats wrong?
I had a similar issue with my Crosley turntable that I recently picked up... and after digging up the manual online all I had to do was lift up on the tone arm and move it to the right (past the holding mechanism) until it clicked, and voila, the turntable started spinning again.
I hope this helps!
Sep 18, 2010 | Philco (R) Classic Turntable CD Shelf...
How do you get the turntable to start turning? We just got a Philco turntable and can't find a switch to get the turntable to turn. We got it used so don't have the instruction manual.
A lot of turntables start moving when the arm is moved to the record start. The turntable should move when you move the arm to the edge of the platter, even with no record. If it doesn't, listen to see if the motor spins. Then lift up the platter matt to see if the belt has slipped off.
May 06, 2010 | Philco (R) 841.205 CD Shelf System
My turntable does not work. Is there a lock ?
Try this - GENTLY move the phono arm to the RIGHT until you hear a click (of course, do this after you turn on the power via the volume dial and set the other dial to"phono"). Doing this turns on the turntable when you haven't used it in awhile. This worked for us, hope it works for you.
If it doesn't work, you can check the belt by removing the tiny clip at the center post and gently lift the turntable platform/tray to peek at the motor and belt underneath. The pulley is on the right at the 2 o'clock position, the belt should be in contact with it.
Aug 05, 2009 | Crosley CR248 Turntable
Turntable does NOT turn.Crosley CR66 vintage Radio and Turntable
Try this - GENTLY move the phono arm to the RIGHT until you hear a click Tof course, do this after you turn on the power via the volume dial and set the other dial to"phono"). Doing this turns on the turntable when you haven't used it in awhile. This worked for us, hope it works for you.
May 27, 2009 | Crosley Audio Players & Recorders
Technics turn table
under the tone arm next to the lever ther is a sort of plastic bar which lifts the tone arm when lever is up right, look along that bar and there is a screw which you turn as you would to tighten anything.you will see the bar move down,try again and if you still have the same problem repeat the process till done......
Jul 03, 2008 | Technics SL-1210 Turntable
Philco (R)  Retro Nostalgia Music CD&Turntable Record Player with AM/FM Radio Shelf System Logo
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Morne Olivier
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
