Question about KitchenAid 24 in. KUDP01IL Stainless Steel Free-standing Dishwasher
Dishwasher stopped working, abruptly
It's approx. 5 years old - wife said it smelled slightly like burning - it shuts off the breaker on the main board - removed standing water via shop vac - as soon as you turn on breaker, dishwasher triggers it off - I have no idea - I removed bottom panel but to untrained eye everything looks fine. Model #: KUDP01ILBS6
  • tubedrev Jul 16, 2010
    second question was submitted
  • 10,865 Answers
Hello. Since it kicks the breaker off you probably have a bad motor. The sad reality of life today is that the cost of a major appliance repair is generally not the way to go. Cut your loses and get a new dishwasher. It will be much more economical to operate due to new technology and it will have a warranty. IF you chose to install it yourself, you would be in a new dishwasher for as little as $400. The degree of difficulty on the tear out and reinstall is actually low. The instructions will be excellent if you stickwith a name brand. J.
Posted on Jul 15, 2010
  • tubedrev Jul 15, 2010
    thanks for the help - is this the only option, a blown motor? - and what would be the approx. cost for a new motor?
    Hey: just wondering if you got my second question about the motor. Thanks for the help.
LG LDF6810ST won't power up there is power going to dishwasher
the main control board is fried from what you've described, you will need to dismantle it and remove the board (there will likely be visible signs of damage if there was a burning smell) relatively easy and cheap to replace
Jan 01, 2017 | LG LDF6810ST Stainless Steel Built-in...
I smell my motor. Is it worth replacing, or buy new?
5 years seems short for a major appliance designed to give 10 years or more of service. I'd say it's worth repairing yourself.
Just make sure it is the motor, then dig a little deeper to find out why it failed. It can be from being bound up because of a jam in the pump, a leak causing the bearings to freeze, or in the case of inductive motors a failed starting/run capacitor.
I've seen failure of the waste water gate/valve solenoid due to a timer issue. You'll have to do your detective work and once you know exactly the part that is eminating the smell, you will have a path to backtrack from.
Remember, water and electricity don't mix and shut both off before working inside the dish washer!
Jan 30, 2016 | Kenmore Dishwashers
Shuts off after approx 5-10 seconds; then slight burning smell
I would take the top off and continue to clean the lint out of the machine
Dec 22, 2014 | LG DLE3733 Electric Dryer
Kitchenaid Dishwasher trips the 60-amp main breaker but not 20-amp.
Its possible that there may be load on that circuit from other appliances. Had an issue myself with stove and laptop on same circuit.
Check other appliance attached to the 60amp circuit (microwave, stove, kettle etc)
May 13, 2012 | Electrical Supplies
My dishwhers keeps tripping the main fuse not long into a wash progamme. It doesn;t do it on the rinse cycle though only a wash programme. I then have to reset it and try again but it happens again if a...
It could be the main fuse..Not the proper amps for the dishwasher.It might have a loose ground...Every so many years you have to tighten your wires in your breaker box...Then will become loose...What I do is shut off the big breaker at the top of panel..That shuts off all power coming into house...Then with a flash light I tighten them all..You will be surprised how many are loose...But call a electrician if you don't know what your doing..It could kill you..I'm not saying this is your issue...But definitely be the problem....
Jan 12, 2018 | Neff 24 in. S4456N4 Built-in Dishwasher
My bosch shu43co5 made a burning smell and stop working in middal of a wash the breaker seems to be fine and trying the power button/ powerscub/ reg wash don't get any lights on. what is my next step in...
Welcome to FixYa.
**Before I begin I will inform you B/S/H/ ( Bosch Thermador, Gaggenau ) issued a recall on certain models between 1999 - 2006 depending on the serial number.** Here's the link so you can see for yourself.
http://microsites.boschappliances.com/safetyrecall/dishwasher/
Aside from that and based on your post "my bosch shu43co5 made a burning smell and stop working in middle of a wash the breaker seems to be fine" it may just be a loose/burnt connection in the dishwasher junction box.
**Now I would start by first shutting off the breaker...safety first**
Then removing the kick plate ( access panel at the bottom )...
...and checking the wiring at the junction box for the dishwasher 120vac supply line.
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance".
Typically this will manifest in just the manner you've described.
Let me know what you find and I'll try to assist you further if necessary. I'd still suggest looking into the possible recall for your machine though.
Regards,
Macmarkus :)
Dec 20, 2010 | Bosch SHU43C05 Stainless Steel Built-in...
Hi there, I have a Tricity bendix dishwasher, approximately ten years old. the other night in the middle of the wash cycle, it went pop, tripped the mains at the board and there was a smell of burning in...
You know, I think the best thing to do would be to replace the dishwasher. It is ten years old and a new one would be more energy efficient and you would save money in the long run.
Jun 29, 2017 | Tricity Bendix Dishwashers
Bosch dw shu043 dishwasher stopped working in middle of cycle
Hi and welcome to Fixya. Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
May 19, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher not working
The motor may be burned out or there may be another electrical issue which would also cause the symptoms you describe. Call around and try to get an estimate, and at the same time look at new ones on sale.............one question is how secure will u feel with that maching......now that it has acted up like this.
Sep 07, 2009 | Dishwashers
Dryer
Open dryer's cover and look that the belt is OK and in place (over the tub and the motor) Try to find out from where the burning smell comes from. Does the motor spin ? Let me know with your results and I will do my best to assist you with your problem.
Aug 02, 2007 | Amana DLE330RAW Electric Dryer
KitchenAid 24 in. KUDP01IL Stainless Steel Free-standing Dishwasher Logo
29 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
