Question about Dishwashers
I have a whirlpool dishwasher. 665.16872000. the clean light is flashing 7 times. the unit is not doing anything.
  • 6,784 Answers
HI. Die to the fact that there are Many areas of concern here: i have took the liberty of embedding a visual aide that will guide you through these many areas of concern. Follow carefully.
Posted on Jul 15, 2010
  • 6 more comments
  • Michael Masters
    Michael Masters Jul 15, 2010
    Video:
  • Michael Masters
    RE:
    HI. Due to the fact that there are many areas of concern here; I have
    took the liberty of embedding a visual aid that will guide you through
  • Greg Smith Jul 15, 2010
    followed the directions on your video. still that the same problem
  • Michael Masters
    What were the readings on the high limit thermostat and element terminal?
  • Michael Masters
    Also; What were your findings on the door latch assembly? Where the l1 and 2 sides aligned as stated in the video?
    And finally; What were the result of your wiring inspection? You were instructed to check all wirign connections at the elemsnt terminals, high limit thermostat, control and door latch assembly. What were the results??
  • Michael Masters
    The element should read between 10 to 35 ohms. What did your test reveal???
  • Michael Masters
    Hello there; Still waiting on your test results. I will need the test results to determine which part you will need to replace. You have stated you have done everything in the video I posted. You should have these test results, if this is the case. I need to know what the element ratings are, as well, as the hi limit thermostat ratings as well. I will also need you to report the state of the door lock latch assembly and the latch plate. They must be in good condition and well aligned.The door must close tightly and securely before the element will be able to become energized. I will also need the wiring report. All connecting wiring must be connected, properly, to every corresponding component. Check all wiring connections.
    Standing by........
  • Michael Masters
    • NOTE_ You will need a multimeter to preform the necessary testing needed. It must read ohms and be set to the X1 setting.
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
Tip
Clean light flashing on dishwasher
if you have a whirlpool/ kenmore dishwasher and the clean light is flashing 7 times then pauses and then repeats, it is a problem with the heating circuit.
follow this keypad operation: push the high temp wash, air dry, high temp wash, air dry. this will put the unit into a service mode and it will run a short diagnosis cycle. after it gets done, about 5-7 minutes, then it will reset and allow you to use the unit again.
make sure the water is hot enough at your faucet at least 120 degrees, and the door is getting closed tight.
on Jan 18, 2010 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My Whirlpool DU1145XTP won't turn on. Clean light
Check the themistor in the control panel. Radio Shack sells these for about $1.30 each. I replaced the one in my dishwasher three years ago and have had no issues since.
May 16, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
The clean light is blinking on the dishwasher. i
if its flashing 7 times. make sure hot water 120degree goes in unit. if water is satisfied then replace heater and main board. its a kit
Feb 09, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Mod #gu2500xtpb1 clean light flashes 7 times
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats--
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence--
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes). You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool clean light flashes 7 times
Actually, the button order to put it in a diagnostic cycle and clear the blinking clean light on the gu2500 is HEATED DRY, NORMAL, HEATED DRY, NORMAL not the other way around as Iden had posted.
Mar 27, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
