Question about Xerox WorkCentre XD100 All-In-One Laser Printer
There is a line across each copy in the exact same place
There is a line across the page in the exact same place on each copy. Do i need to replace the drum cartridge?
    Genius:
  • 1,121 Answers
Some times is some dirt on fuser unit, check for any dirt or a scrached fuser roler
Posted on Jul 15, 2010
When I copy papers on my Canon imageRunner 2800 there are 2black lines in the middle of the copied paper. How do i solve this problem?
Hello mike,
You may have a fairly easy problem to fix, and that's good thing ! If the lines only appear when you use the document feeder then we can handle this. Please place a document on the platen glass and make a copy. If the copy looks good then we need to clean your "scan" glass. The scan glass is the small glass located to the left of the large platen glass. It's about 3/4" by 14",and will only cause problems when you use the automatic doc feeder.If it gets dirty then thin lines will show up. If indeed this is the problem then I have a test u can use that will help you Take a plain piece of paper. Mentally divide it into 4 squares and then simply write the numbers 1,2,3,4 on each quadrant. At the top edge of your newly formed test document place an arrow pointing away from the body of the paper, and it needs to point "UP".. Now draw an arrow on the test document that points to the left "lead " edge. Put your newly constructed test target in the document feeder and make a copy of it. Now, you KNOW how you placed the test document, so lets look at the copy. If you have lines only thru the document feeder, then look at the copy you made and notice where the lines are. Ok, now you know where the lines show up on the copy, so lets take your "test" document and compare them side by side.Once you have made this comparison, and can see where the lines show up, take the ORIGINAL test document and place it IMAGE UP (1,2,3,4) on the glass. This will point out exactly where the dirt is. By looking at the copy that has lines, and where they show up on the page, you can use the test page that is laying face up on the glass and compare the 2. BOOM !! You can look towards the small scan glass and find the dirt that is causing the lines. With your copier, IF you place a document on the glass then the scanner moves to "scan" the document. But if you use the document feeder, the scanner stays in one spot and the motion of the document moving ACROSS the scanner and is scanned like a bar code. If there is dirt on the scan glass then a line occurs instead of a "blob" as you would see if you used the platen glass.I hope this all makes sense (I tend to ramble) and I hope it helps you. You of course could have far more complex problems. But your description of the problem sounded like my remedy/idea might be just what you need. Take care and good luck. if I helped you please let "fixya" know. SPINAL
Apr 02, 2011 | Canon Office Equipment & Supplies
I have a dell mfp 3115cn copier, fax, scanner. Th...
the fault is a mark on the glass over which the paper passes when being copied. it is the rectangular glass that is probably only 1cm wide but the full A4 length across the screen. Clean the mark off this thoroughly and voila, fixed.
Bristolprinters Ltd - with compliments!
May 21, 2010 | Office Equipment & Supplies
Black spots in the dram ricoh 450
Are the black spots on all copies. if they are only on teh copies done from teh glass scan then it could be dirt on the g;*** plate. if from all copies it is the dev or drum area.. are the dots moving across the page in the same place if you do lots of copies this means it is the drum that is damaged.. if they are blotchy marks it could be toner build up.. if the marks are in a line across the page open up the side door adn look at the hot roller in the fuser the coating could be damaged and the roller need replacing..GOOD luck A
Sep 29, 2009 | Ricoh Aficio 450 Copier
Faint red line across page when making color copies or printing in color from computer
Some possibilities are:
1) Dirt on the glass, dirt on the glass strip for the doc feeder, or dust on the mirrors. This would be the case if the line only showed when copying and not printing.
2) Toner dropped onto the charge sawtooth.
This may be possible if the line is intermittent and only showed up for 1 or 2 colors.
Open the front door and remove the waste toner box. To the left of each drum there is a green organ-stop type stem. Pull and reinsert each stem. You will hear a zipping noise. These are your charge scrubbers.
This may be not as likely if the line shows up in the same place on all 4 colors
3) Toner or dust on the lens
In the area where the waste toner box goes, look for a grey stick with a white cushion on the end. This is your lens scrubber. Look in the area under the charge scrubber on each drum cartridge for a gap. Insert the scrubber cushion side down into the gap and run it forward and back to clean the lens.
4) Transfer belt blade not cleaning
This is best handled by a service tech since the mylar belt is very fragile. The squeegee blade that cleans the transfer belt between copies is missing a spot. The blade needs to be taken off the belt, cleaned and repowdered. Recently, Sharp made changes to the composition and thickness of the mylar in the transfer belts. Overpowdering the blade or belt when it was changed may cause improper cleaning of the belt creating lines across the copies. Often the condition clears up after a couple of days as the gap between the blade and belt is sealed.
This is most likely the cause as the line shows up in the same area for more than 1 color.
5) Transfer belt and/or blade is worn out
If the belt is worn the blade must be replaced but not vice versa.
6) Clogged waste augers in the drum cartridges.
Waste toner may cake up in the drum cartridge and knock loose on the drum.
It may be time for full maintenance on the machine.
Jun 02, 2009 | Sharp MX-2700N Color Copier
Light lines showing up in all colors
I think this is rebadged OKI in which case it has LED array that goes across drums. You should see strips of LED's across under the top of the lid when you open it. Clean these with ALCOHOL swab ONLY. Let dry and try!
Apr 27, 2009 | Xerox Phaser 7300DN Laser Printer
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
ADF has something on it causing a stripe on all copies
Lift the document feeder and clean the narrow glass, (next to the glass where you place your originals). Documents are scanned across this glass when automatic feeder is used, thus a small piece of dirt becomes a line down the page.
Feb 24, 2009 | Canon ImageClass D880 Copier
Black lines on printed material
check the optics section the remove the exposure glass anh clean the fisrt,second, and third mirror
Feb 16, 2009 | HP LaserJet 3050 All-In-One Printer
Streaking
Hi there it will be either the drum unit for the color streaks you are getting or the fuser unit. Check the drum units for the streaks on them also check the fuser but the clue is when you have the streaks in different places. Most likely to be the drum units. You will need to replace.
Thanks J
Oct 30, 2007 | Ricoh Aficio CL7000 Laser Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
112 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
