I'm trying to find manuel and info on model #10ajb24a01 its size and ratings weather king central air unit
  • 455 Answers
Hello DDD you got a 2 ton 10SEER unit.Standard efficency rating.RHEEM.com might have the book use the model# .thanks
Posted on Jul 16, 2010
I need to know what size run capacitor for compressor I need on a Weather King model 10AJB24A01?
You can see a pic at the web address provided. The number is located on the old capacitor and frequently a replacement will not have an exact fit that requires you to modify the space it rests in. The updated part number is
43-25135-16 it is a 3/30 Mfd capacitor. 30 3 Mfd 370V Oval Capacitor 43 25135 16
Sep 16, 2015 | Weather King Heating & Cooling
Trying to get info (tonnage seer rating) on a weatherking mod# 10ajb48a01 condencing unit to find a matching evaporator coil and cannot find anything on internet
This is a 4 ton model condensing unit. You can go up 1/2 ton for the evaporator, meaning a 4 1/2 (A) coil will work just fine and allow a bit more cooling capacity.
Sep 10, 2011 | Weather King 12AJA4801AH Air Conditioner
What uf capasitor on model 10ajb24a01
Look it the side of the cap it will be on it.
Jul 06, 2011 | Weather King 10PJA2501AH Air Conditioner
We have a weather king central air unit mod# WAKA-030JAZ. ser#5339 mo6959417. volts 208/230. compressor rla 13 5/13.5. outdoor fan motor f.l.a.9. mfd 02/05. hertz 60. l.r.a.76. hp1/6 min supply...
I would bet the outside units contactor is bad. This is the device where the two thermostat wire connect outside. If this is pulling in/out as you turn the stat on/off then it is working. I just fixed one yesterday with the same symptoms and found the start capacitors were bad. If they are bulged at the top or bottom then they are bad. Good luck.
Jun 19, 2011 | Weather King Heating & Cooling
How can i find out the capacity of my weatherking 10ajb24a01 central air unit?
Hello eveyone,i found the right value for my central air ,the Capacitor is 60uF/5uF/370v. I installed this last summer & it works great. I bought mine in our local refrigeration parts store. but they also have this in ebay ,ebay item #190526958646,hope this will help you too,goodluck Dave
Oct 24, 2010 | Weather King Heating & Cooling
I have 2 Weather King units model numbers 10AJA2501 & 10AJA6001 and am trying to determine the sizes and SEER ratings of each
Hello Larry Both units are 10 SEER.Standard rating ,not efficent units.JA25 is a 2 ton unit,JA60 is a 5 ton unit.Thats 24,000 BTU & 60,000 BTU.I hope that helps.
Jul 08, 2010 | Weather King 10AJA2501AH Air Conditioner
Need to have an idea of the number of kw needed. max load normal
Most central air units depending on age and SEER rating will draw 220 volts of power and anywhere from 3 to 30 amps of power while operating. calculating a kilowatt draw would need to be done by your power company most likely. Also try looking at your power bill or calling the power company and asking for your detailed usage on a daily basis most of them print it on the bill I think and look at it for a time of year that you are sure it was warm and the system was running. Obviously the system will draw much more power the hotter it is outside so if you are needing an exact number for calculating a use for something like a generator to power it you should always go with a little extra. good luck hope this helped.
Sep 20, 2009 | Weather King 10AJA6001AH Air Conditioner
Filter size
Thats an A/C, what is the indoor unit model #? Does it have a filter box? If so what size? If not do how does your filters sit in the unit?
Jun 23, 2008 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
689 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Marvin
Marvin
