I am trying to get my tv channel set on channel 4 but i dont have a channel changer to do it how do i fix this problem
  • 3,866 Answers
I would say try to use the up/down channels buttons on your tv, or get a universal remote control at your local radio shack, the issue on most tv's is that if the signal was not strong the first time the tv deletes the channel. If there is a menu button on the tv itself press that then go to your channel setup and scan for channels but make sure your deivce that is on channel 4 is putting out singal or is turned on.
Hope this was of some help
Posted on Jul 15, 2010
Lost remote and now cannot move to any channel except 3 and 4
If you have a vcr, set it on channel 3 or 4 to match the tv, hook it to your set and use it as your channel changer until you can come up with a better solution.
Jan 17, 2011 | Toshiba 27A34 27" TV
Can't get TV picture after hooking up PS 2
How many sets RCA ports (for Video 1 / Video 2 so on and on) does your TV have?
Jul 26, 2008 | Panasonic Televison & Video
Tuner appears to be stuck in channel 4. Cannot change Channel.
It is a tuner selector problem, either the processor controller ic is the problem, or the selector ic. The easiest solution use a VCR as your channel changer, and check to make the VCR is set to channel 4.
Jan 03, 2011 | Panasonic CT-27SL14 27" TV
L32W761 32 in. LCD TV: my channel changer stopped working only the power ...
Channel changer from the remote? or from the TV? if it is from the remote, that's an easy fix, take off the batteries open the back of the remote, clean the circute board the one that is painted green, clean the remote contact pads as well the one that has a black dot like thingy with cotton balls slightly damp in rubbing alcohol, let it dry put it back together and replace with a new battery.
May 18, 2010 | Envision L32W761 32 in. LCD TV
Hi Someone gave me this old Sanyo TV Model # 31C4760, When I connect it with my cable it catches only basic (13 channels) instead of 60 channels. How should I see all the channels? What should I do?
If it is very old (with rotory/manual channel changer), you are out of luck unless you get a cable box from your cable company - this will let you set your TV on channel 3 or 4 and the cable box will find all stations for you. The cable box goes between your wall cable and your TV.
It your TV has an electronic tuner with a remote, try going into the setup menu and select signal source as CATV instead of antenna.
Please rate me.
Nov 20, 2009 | Televison & Video
Tv not working with cable box
Insure your TV is set to channel 4. Then go into your TV's menu and make sure it's set to CABLE and not AIR. There is no need to program your tv, as long as it's on channel 4 and set to recieve Cable it will be fine.
Mar 26, 2009 | RCA F27665 27" TV
Philips 32'' when turned on picture goes off after 5 seconds
hello. ok try this. first take the remote's out of the room the tv is in.!!! yes both of them. then i want you to turn the tv on with the power button on the front of the set. and tell me what .? happen's..and please dont try to turn thechannel or any thing else !!! .just turn it on.!!! "am" waiting
Jan 03, 2009 | Philips 32PT6441/37 32" TV
#4 & #5 buttons do not work on my remote. Channel 55 wont come in either on my tv
I had that problem 2 my channels disapeared one by one and some will skip yes...
I always use on my remote controll :
1 menu
2 Ch tuning
3 auto
and then wait untill it has found all the channels
Oct 02, 2008 | Orion1934 19" TV
Sharpe LCD TV...model LC-195K24U-K...can't get to change channels
what causes a line down the middle of my screen
Jun 08, 2008 | Televison & Video
Trying to watch vcr on channel 4, but the vcr is set to channel 3
You can watch the TV programs
with the tuner of the unit. (Usually
channel 3 or 4 of the TV is
available for the RF converter
setting.) Be sure to connect the
unit to a TV using the RF cable.
Select channel 3 on your TV.
Press [VIDEO/TV] on the remote
control.
• If noise appears, change the
RF output channel of the unit to
CH 4 by pressing [VIDEO/TV]
for 3 seconds. The RF output
channel will alternate between
CH3 and CH4
Nov 20, 2007 | Philips MWD2205 DVD Player/VCR
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Electro Med Services...
