Question about Kenmore 24962 Top Load Washer
I have a Kenmore Elite 2496(24962300) model washer. It seemed not to spin but after careful observation I found that it does 2 things. When I first turn it on to start the cycle the water starts to fill & it starts to agitate immediately before even filling. The water valve seems to work since I can keep the top open & when it gets to the proper level the water cuts off. 2 - when it goes into the final spin the water also cuts back on while it is trying to spin. It drains before that ok. If I manually cut off the water source & let it spin it will finish the load. Is this a timer or control problem? Any suggestions ?
reg501
  • 413 Answers
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 04, 2008
bozcro
  • 867 Answers
SOURCE: I have a kenmore top load washer model
there seems to be a sensor problem of some sort or sticky switch, you may need a repairman for a complex problem as this
Posted on Jun 14, 2009
canbruce75
  • 1776 Answers
SOURCE: does not fill
Check the solenoids at the water inlet valve for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty solenoid.
Hope this helped and best wishes.
Posted on Aug 14, 2009
  • 401 Answers
SOURCE: I have a Kenmore washer model 110-24962300
There are plastic parts called "dogs" that need replaced. They are inexpensive and not hard to do.
Posted on Jan 02, 2010
ftw1952
  • 10319 Answers
SOURCE: My Kenmore Elite top loading washer keeps filling
the shut off solenoid is not functioning correctly. Check that and the relay to it
Posted on Aug 29, 2010
Have old kenmore elite he3 washer. Have wet laundry after spin out. Have checked ball be low drum, replaced strainer, pump motor, cleaned all hoses. Did a test run in the drain and spin cycle. For like 7...
If the washer is taking more water during spin, then most likely it is thinking the water level is low for the load. It is a smart washer and tries to adjust water according to load. This can mean the level sensor is giving wrong sensor. I would try to run the washer with a cleaning agent (not bleach) available from specialist stores or washing machine retailers.
Also observe if the drain pump is running all through the spin cycle. If not that is likely causing water to remain. But controller is thinking there is no water and not starting the pump when required.
You should be able to locate the parts in these diagrams.
KENMORE ELITE Washer Parts Model 11049962600
Sep 20, 2014 | Washing Machines
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis HE/ Error Code F1
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Jun 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calpso washer
i am having the same problem with my calypso model 110 top loading washer. i found that the drive to the pump was spinning on it and stripped out the teflon gear. i believe the motor to the pump is working but, the pump isn't spinning i don't think. thats why the water isn't coming out, and the cycle won't move on. i can't seem to find the 8527775 pump by itself. the geneic ones i found have a different fitting to the motor.
Sep 17, 2007 | Kenmore 20172 Top Load Washer
Kenmore 24962 Top Load Washer Logo
215 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
