Question about Saitek X36 Flight (J24) Joystick, Throttle
Saitek X35/X36 Need Repair
Does anyone know if a Saitek X35/X36 controller can be re-conditioned or repaired, and if so who should I contact?
Has anyone tried Saitek m80x wireless notebook mouse on Windows 8.1???? In my case it does not work.
Make sure you have the latest driver for the mouse from the mfr.
http://www.saitek.com/uk/down/drivers.php
Jun 11, 2014 | Computers & Internet
Need (cd) drivers
Only for XP http://www.driversdown.com/drivers/10831.shtml
Jul 25, 2011 | Saitek X36 Flight (J24) Joystick, Throttle
Need. Drivers
Computer accessories least require drivers. observe the device for system compartibilities.
Jul 24, 2011 | Saitek X36 Flight (J24) Joystick, Throttle
Worn out to fast at the top end of the throttle,can it be repaired,have already changed 2 over,replacement part or repair , many thanks js SAITEK THROTTLE QUANTRANT
Unfortunately Saitek does not have a repair service therefore no spare parts are available at all.
If your Throttle Quadrant was bought less then 2 years ago you should be able to get a replacement for it from your retailer or from Saitek.
Hope it helps...
Apr 07, 2011 | Saitek Pro Flight Throttle Quandrant...
Hi my name is jatt and i don't know how profile saitek cyborg pc
Hi there, go into control panel. When in control panel, click switch to classic view. Then click on game controllers and you will have settings for your game controller.
Jan 18, 2010 | Saitek Cyborg Rumble Pad Game Pad
Saitek P3000 RF Wireless Gamepad + Dock Station Biggest Issue
where you hook up the batteries, make sure there is no corrosion on the contacts, it will look either green or white and have a flaky look to it.
If you don't see corrosion, try a know new set of batteries. If that doesn't work then the problem is in the dockstation.
Dec 17, 2009 | Saitek (p3000) Game Pad
I have a Saitek P3000 gamepad, cant turn on?
i can not charge my batteries and i dont know how to turn it on
Mar 16, 2009 | Saitek (p3000) Game Pad
Saitek 3D Gold manual
The buttons do what you want them to do. The stick is programmable. Most games allow you to map the joystick controls the way you want. With others, you can map them with the Saitek software. Download the drivers and software at:
Jan 25, 2009 | Saitek Cyborg 3D Gold Joystick
Saitek universal commander remote control
Here are some codes for the remote saitek 3001,3002. sony 3021,3022,3023. you press and hold the SETUP button for 1 to 2 seconds then you put the code 3001 or what will work the light will turn then when you put the code in if it works it will turn off then try the remote.
Aug 23, 2008 | Saitek Video Game Consoles & Games
Saitek X36 Flight (J24) Joystick, Throttle Logo
246 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Marvin
Marvin
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
