Question about Microsoft Xbox 360 Console
The disc drive has damaged / marked two of my discs rendering them un playable.
Depending how deep the scratch is it may be possible to polish out with a fine quality cutting compound, I have some for polishing glass it has worked on mine. Was the console moved or tilted when the disk was spinning? As this will do what you have explained:(
Posted on Aug 22, 2010
Will not recognize disc sat nav peugeot 406
possibly the dvd reader optic is dirty try running a cleaner disc in dvd drive also check dvd for damage scratches etc. even small marks can affect root directory rendering disc useless
Oct 25, 2013 | 1999 Peugeot 406
How do i get my th-a9r to play dvd-rw
You can't. The Laser will only Play +R & +RW.
Non-playable discs
• DVD-ROM • DVD-RAM • DVD-R • DVD-RW
• CD-R* • CD-ROM • PHOTO CD • CD-RW*
* Audio formatted CD-R and CD-RW can be played.
• Playing back discs list as "Non-playable discs" above may
generate noise and damage speakers.
Apr 23, 2011 | JVC TH-A9 System
Tried to play 'alligator Dundee" on DVD, but disk
It all depends on the region coding of your player and the code on each disc.
For example, if the DVD region code is 1, and the player is region 4, the disc will not be compatible. The same can be said of region 4 discs in a player specifically intended as a region 1.
Region-free discs (or '0') should work with this player. It sounds like a restriction from region coding between the discs and the player. There isn't much you can do except use discs marked 'region 0' or 'ALL' (playable worldwide), or those which match the code on your player. Check your disc's cover for region code information (if any).
I do not recommend region hacks as these may damage your player.
I haven't heard of Alligator Dundee, but after some reading up on it, it appears to be a parody of Crocodile Dundee, which was more popular.
Mar 07, 2011 | GoVideo Go Video DVD/VCR Combo
Disc won't play
As the Wii uses discs that can be scratched, dirty, or otherwise damaged -- it's important to first check the disc.
Look for fingerprints or other smudge marks. If you have dirty marks on the disc, you can wash it off with regular dish soap and water. Not too much soap though. Make sure you dry it off with something very soft [like a microfiber cloth] before you put it back into your Wii.
Second -- scratches will stop a disc from playing... or the disc will play until it gets to the scrached section then give you an error. Check and make sure there are not too many -- or deep scraches.
If a scratched game won't play through but other games play just fine -- chances are the disc is bad. However, if nothing is playing through on your Wii, not even a new game, there is a problem with the Wii's DVD drive. There is a laser in the drive that reads discs -- and many other moving parts in there. The following website sells the Wii DVD drives. It's not too difficult to replace yourself:
http://store.richspsxparts.com/wiiredvddr.html
Sep 06, 2010 | Nintendo Rock Band for Wii
MY CONSOLE KEEPS SAYING CAN'T READ DISC
The most common reason for the games not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
Take care.
Aug 20, 2010 | Nintendo Wii Console
Damaged Games
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that Xbox owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally required to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 disc repairs, visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair.
You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
Feb 04, 2010 | Microsoft Xbox Console
Fifa 10 will not play in my x box 360
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on a discs, will render the game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error”.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally rerquired to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 scratched or laser burn disc repairs or to get discs professionally repaired, visit:
www.discREPAIR.ie
You can send your discs off to this Disc Repair Service and the discs shall be sent back as good as new.
Dec 31, 2009 | Video Game Consoles & Games
Playing new fifa2010 on x boxx 360. working ok and then froze stating ''clean with soft cloth'' tried this but unsuccessful
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render the game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error”. Best remedy for starters is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs.
For further help on Xbox & Xbox 360 disc repairs or to get discs professionally repaired, visit:
www.discREPAIR.ie
Check the More Info Section & FAQ section for more details on disc repairs.
Send your discs off to this Disc Repair Service and the discs shall be sent back as good as new.
Dec 26, 2009 | Video Game Consoles & Games
Un playable discs
i think you have a dvd drive problem. Your gonna have to take your xbox apart, (there are videos on youtube on how to take a xbox apart). Then your gonna have to take the dvd drive apart, and there should be a magnet that is stuck to the top of the dvd drive.
Nov 23, 2008 | Microsoft Xbox 360 Console
Non playable discs
Hi i had the same problem on my 360,
so i got a new laser off of ebay,
and that didn't fix it so then i read some fourms,
and found that my drive motor that spins the disc was broken,
so i replaced that and now the xbox is working like new again :)
Jan 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
