Question about Dell E173FP 17" LCD Monitor
I have a blank Dell E173FP monitor with the green blinking light. I have ordered and received the repair/replacement parts. Can someone please respond with detail instructions to fix the problem? Thank you...
  • 732 Answers
Yumaparkie, You mean to tell me you haven't been to YOUTUBE to see all the video clips of Dell E172FP, E173FP lcd monitors being repaired?? Do that first, then come back here if you still need help.
12fixlouie
Posted on Jul 23, 2010
My Dell E173FP monitor will not come on. I have unplugged and replugged the cable from monitor to hard drive case as well as the a/c power cord. I have rebooted the computer several times and all I get on...
The dreaded blinking green led without a display, means that the backlight circuit has failed on this monitor. Typicalll the transistors that drive the backlight transformers short out and fail. I have fixed this on my monitors twice. Very common failure for this monitor and can be fixed quite easy if you know how to use a soldering iron and a meter. They even sell a repair kit on ebay that provides parts to repair this monitor. Just go to ebay and search e17fpb repair and to find it. Hope this helps.
Jul 07, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
We have the monitor apart and LED light keeps blinking green. What to do?
We have repair guides for several of the Dell monitors posted on our web site at:
www.ccl-la.com/badcaps.htm The guides give full parts lists and locations with support pictures. You can also chat online with our techs at
www.ccl-la.com/chat.htm
There are several different versions of the Dell E173FP they are indicated by a third letter at the end of the FP and are c, f, and b. Each version take different parts for the repair. Let me know which model you have and we can further help out.
I hope this helps, If so please rate or solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 04, 2009 | Dell E173FP 17" LCD Monitor
Dell LCD Monor light keeps blinking green, screen is black cannot stop blinking unless unplugged from power source but upon plugging back in monitor starts blinking green again
Your monitor has a bad power supply board. This happens often on LCD monitors because of the heat buildup in them. If you can solder them go to our web site at:
www.ccl-la.com/badcaps.htm We have a step by step dis-assembly and repair guide for your monitor. There are several versions of the E173FP some end in b , f, or c so be sure to check your monitor.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 27, 2009 | Dell E173FP 17" LCD Monitor
Dell Monitor Problems
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 17, 2009 | Dell E173FP 17" LCD Monitor
Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Final Answer to Dell E173FP blank screen problem?
Check out this link http://www.lcdrepair.us/Installation.html
They have help videos on that model and sell repair kits as well as the whole board.
Jun 12, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
E173FP monitor fix
Well, here's Dell's answer:
http://support.dell.com/support/edocs/monitors/E173FP/En/trouble.htm
Mar 30, 2008 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
270 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
