Question about Kenmore 22062 Top Load Washer
How to get cabinet off - Kenmore 22062 Top Load Washer
  • 5,911 Answers
If you are referring to how to remove the exterior washer case on a Whirlpool manufactured top loader, the following link explains the procedure step-by-step:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
This procedure is much easier than it sounds. However, if you require any further assistance, please post back with any symptoms you may be experiencing and let me know. I hope you find this information helpful. NOTE: Kenmore is manufactured by Whirlpool so these instructions do apply.
Posted on Jul 15, 2010
How to clean Metal Filing Cabinets?
Metal filing cabinets are tricky to clean. Start by cleaning the exterior of the cabinet. Use clean water to clean the outer side with sponge. Remove the rust by applying navel jelly on them and remove it completely by clean cloth. Use fine sandpaper to remove the flakes and mineral spirits to get rid of the dust. At last paint the metal cabinet by spray paint or liquid paint.
Visit Fire Cabinets Direct Ireland for buying fireproof cabinets & chubb cabinets in online..
Mar 05, 2016 | Home Security
Tip
Sink Cabinet Replacement Bottom
IF your sink cabinet bottom is water damaged and in need of a replacement, this video gives step-by-step how to information for fixing it. This video was created by a cabinet professional who specializes in fixing Formica kitchen cabinets.
It is very informative for the person who likes to do it yourself" when it comes to repairing things around the home.
Tools and materials needed:
Saber saw
Diagonal cutters
Hammer
New sink cabinet bottom
Caulking
Caulk gun
Clorox Bleach
Three Support Struts
L-brackets
Finish nails
How to do the Repair:
Take the doors of the kitchen or bathroom cabinet off.
Remove the water damaged sink bottom by cutting it in half from front to back. You may need to use the hammer at this point. Just be extremely careful to not damage the plumbing.
Break off the staples with the diagonal cutters.
Clean the mold with the Clorox Bleach.
Install the struts designed to support the new sink cabinet bottom. Use L-brackets if necessary for attaching the center piece.
Install the new sink cabinet bottom replacement board. Attach it with finish nails.
Clean the inside of the kitchen or bathroom vanity cabinet.
Caulk all interior areas of the sink cabinet bottom.
Replace the doors.
Every sink cabinet is built differently. Make sure to examine how the cupboard was built to determine the best method for replacing the bottom of the cabinet. If you have a center style, you will need to cut it out and reinstall it using L-brackets.
on May 26, 2010 | Home
What is the difference between a china cabinet and a curio cabinet?
China cabinets are more often used to store fine china dish sets. Most often, people choose to display china that is not used very often, usually around Thanksgiving/Christmas. They are considered a more formal piece of furniture. Curio cabinets, on the other hand, are used to display various items of importance.
Sep 02, 2012 | Acme Furniture
Does Howard Miller only make curio cabinet or also other styles of china cabinets?
Howard Miller also makes wine and bar cabinets, personal storage cabinets, and entertainment cabinets.
Aug 13, 2012 | Furniture
Lid switch needs to be replaced
Disconnect power then release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine. Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Jan 23, 2011 | Kenmore Washing Machines
How can I replace the pump belt of a washing machine Sears Kenmore model #110.82671710 stock #26717
The Kenmore top load washing with the given model number 110.82671710 is a direct-drive type and doesn't have a pump belt. The pump is directly coupled to the rear spline of the motor.
The cabinet needs to be removed if access to the drain pump and replacement is necessary. Remove the screws attaching the bottom front corner of the console to the top of the cabinet then pull forward and up on the console and lay it back on the hinges.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base. Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up and set the cabinet aside.
With the cabinet removed, pry the clips securing the pump to the motor off and remove the pump.
Detach the hoses from the drain pump and attach it to the new one then install it back into the rear spline of the motor and secure it with the retaining clips. Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Dec 23, 2010 | Kenmore Washing Machines
Can you directly hook a sr16 to a peavey bass speaker cabinet using the output mono on the sr16 to send or retrn on the cabinet?
You can, however a bass speaker cabinet will NOT handle the higher pitch sounds needed for cymbals and snares, etc. You would connect it to the return AND doing so would DISABLE the other inputs of the bass speaker cabinet.
If you want both a guitar and drum machine into the cabinet, you need at least a small mixer or a speaker cabinet that can take two channels input simultaneously.
Plugging into the "return" of the cabinet DISCONNECTS the power amp from the preamp section in the cabinet.
Nov 09, 2009 | Alesis Sr 16 Stereo Drum Machine
How do I replace the water intake valve on my whirlpool top loader.
Whirlpool, Kitchen Aid, Kenmore, Roper, Estate, after 1985
• The valve will be mounted to the back of the washer with two screws. However, you must remove the valve from inside the washing machine, and this requires you remove the entire washer cabinet, which consists of the top, front and sides.
• Remove the two screws in the lower corners of the control panel.
• Lift the control panel up high enough so it stays up and back.
• Disconnect the wire harness connector.
• Using a flathead screwdriver, snap out the two gold-colored spring clips at the top of the cabinet on the left and right sides.
• The cabinet will now lift up at the back. Pull the cabinet up 10-12 inches and then slide it forward 2 inches.
• Remove the cabinet completely and set it aside.
• The valve will be on the right side of the washer at the back. It’s the device to which the water fill hoses are attached.
• Label the wires from the valve and remove them.
• Remove the water feed tube(s) from the valve.
• Remove the screws holding the valve to the back panel.
• Install the new valve in the reverse order.
• Reinstall the cabinet. (Note: As you follow this procedure, do not force the cabinet in any way. When done properly, the cabinet will go back together very smoothly.) First, tilt the cabinet toward you 10-12 inches while you “walk” the cabinet back onto the lower frame of the washer. (This will be easier if you have the washer lid open so you can see inside the cabinet at the same time.) The front edge of the cabinet slides underneath the base frame, and the sides of the cabinet rest on top of the base frame.
• When the cabinet is resting on the frame squarely, check to be sure the back of the washer is aligned with the cabinet. There are two plastic strips attached to the back of the washer that must line up with the sides of the cabinet as you set the cabinet down.
• Reinstall the two spring clips at the top.
• Reattach the wire harness connector.
• Rotate the control panel back down and reinstall the two screws.
• Flush out the water fill hoses.
• Reattach the water lines.
• Turn on the water.
• Check for and correct any leaks.
• Restore power and test.
Hope this helped you and best wishes.
Jul 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Dishwasher for 32 inch cabinets
Miele makes a G600 series that are 32 1/4 " tall - that would probably be your best bet.
Jan 05, 2009 | Dishwashers
Kenmore 22062 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
