Question about Whirlpool 19.6 cu. ft. Commercial Freezer EV201NXM
Waterpuddling and freezing in bottom of freezer
  • 478 Answers
You have a clogged drainline when it defrost it has no where to go use hot water over and over and a hair dryier to unclog make sure its clear with a clotheshanger made of wire. Then run one more cup of hot water through the line to make sure.
Posted on Jul 15, 2010
Water freezing in bottom of freezer. freezer is 10 years old.
The defrost drain outlet is stopped up and freezing over.
Remove the bottom basket.
Turn the freezer off.
Look in the center of the freezer just below the cooling coils in the bottom of the freezer.
You will see a water drain trough.
It will be full of ice.
Use a hair dryer to thaw the ice and remove it.
The drain will become exposed.
It must be thawed also,so that you can pour water through it and the water goes all the way to the drain pan underneath.
Sep 18, 2010 | Whirlpool Freezers
On the bottom outside of freezer bottom front what is the on and off switch for it located between a red an orange color light
it is the fast freeze button,use it when filling up freezer when less than 1/2 full.red is a high temp warning.orange is fast freeze on/working.
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Some water dripping on the bottom and freezes onthe bottom of the freezer and sometimes theres water on the floor.
The freezer drain is cloged.Drain is in the bottom of the freezer floor in the back you may have to remove back panel. Run wire or somthing down drain tube to clear clog.
May 16, 2010 | Freezers
Water in bottom of freezer
the drain needs to be check for any kind of blockage. if the drain is blocked or frozen over this needs to be cleared
Sep 16, 2009 | Woods Upright Freezer MU07W
My freezer is freezing at the bottom but is not at
Short on refrigerant would be a good starting point, pressure temp relationship should be tested by an opperative.
Jun 27, 2009 | Hoover 9.9 cu. ft. / 280 liter Upright...
Upright Freezer not freezing,
looks like low on freon. that causes freeze up. oddly enough they freeze up when charge is low , just the opposite of what you think they would do. you have a freon leak unfortunately. probably not accessible, and therefore not repairable. i would suggest, cut your losses and buy new. unfortunately for me and all other srevice techs, the days of affordable repair are over, you can now replace cheaper than i can fix and have a warranty and its new... good luck
Nov 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
Sep 23, 2008 | Maytag Freezer MQU2057
Not freezing equally
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
Apr 22, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freeze on bottom but not on top
when you plug it in do you ear a fan running if not plug the freezer on.and at the bottom of the freezer gently hit were you have a grill sometime the fan motor gonna start running and circulate the cool air if it work keep and eye on it for a few days take care cheers
Jan 15, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Whirlpool 19.6 cu. ft. Commercial Freezer EV201NXM Logo
88 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
