Question about Karcher 2500 PSI Pressure Washer
Pressure washer will run with choke on push choke in motor shuts off
    Problem Solver:
  • 13 Answers
The main jet is restricted. Suggest you remove carb and clean/rebuild it.
Posted on Jul 16, 2010
Start OK but if after warm up I push the choke to run, the engine stops, I used 4 time before and idled OK
Push choke to run???then not use on a all ready warm engine you mean you push the GAS lever ? remember a choke can work as a throttle for the engine. it can have a double function if your electric start contact is damaged you can use it to stop the running engine also.
How long you are owner of the machine , read the manual about it !
If before it worked good on this kind of proceedings as described ? then if you mean you push the gaslever to run Try it to do it again without the airfilter. I THINK YOU HAVE An AIR problem by carburator if its so clean the airfilter if its not to old. or replace
You can use for short time the choke in most cases minimize use of the choke short not more then 2 times max you pull.or electric start.
AND very important control in any case allways for THE RIGHT OIL level !!
If the engine is warm(hot) do not use the choke forget it it has no use. control your spark plug electrode i think you will find the cause.
Oct 12, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Ridgid pressure washer motor runs choppy when choke is disengaged
The choke reduces the air flow into the carb. If you are having problems with the choke off, it means that not enough fuel is getting into the engine and it is running lean. When you choke it, the reduced air flow causes the mixture to be correct and it runs fine.
Feb 09, 2014 | Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp...
Won't Stay On
If it's brand new, the first thing I'd check is the oil level in the Honda motor. Most pressure washers are tested then the oil is drained out for shipment. Honda motors have an oil sensor in them that will shut the motor off if the oil level is low. When the motor is off, all the oil is in the bottom of the crankcase and the sensor 'thinks' all's OK. When you start it up and the oil is getting splashed around it will get low enough for the sensor to shut the motor down. Also make sure the gas is turned on at the carburator.
Sep 04, 2012 | Homelite Pressure Washer. Honda 2700 psi...
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
I lost my manual ,how to start the pressure washer
Check gas and oil. With water OFF, pull out choke on washer. Pull the start cord until it starts. Let run for about 20 seconds. Push in choke. Turn on water. Bleed wand line. Insert desired tip. You should be good to go now.
Oct 08, 2010 | Honda Pressure Washer PSI 3000
% hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
Nov 02, 2008 | Karcher 2500 PSI Pressure Washer
Pressure washer wont run unless choke is on
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
May 12, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
255 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
