Question about Nokia Cell Phones
How to remove broken screen and replace with a new one on nokia 6350-1b
  • survey9154 Aug 07, 2010
    Where is the hole in step 2? a picture or drawing would be nice.
  • 36 Answers
At first remove all screw from your ph, then you will see a clip beside of lcd. you unlock that one and put there new one
Posted on Jul 15, 2010
    Novelist:
  • 155 Answers
Hello
All you need to do is simple.
1. Open the back of the phone and remove the battery.
2 .Place the end of the screwdrivers inside the hole,which will usually be on theside of the phone opposite from where the RF grommet was placed, above where the battery was located. Lift up on the latch inside the hole to disengage the antenna cover. Grab both sides of the plastic cover and lift it off the phone. Set the cover aside.
3. Locate the series of screws along the sides of the exposed areas of the phone. Use the Torx screwdriver to pull out the screws and then set them aside in a container so they don't get lost. Lift off the metal or plastic plate that was held to the phone by the screws. Turn the phone back over so that the LCD screen is visible.
4. Insert a flat, thin object like a flat head screwdriver underneath the edge of the plastic cover at the bottom edge of the mobile phone. Lift the screwdriver up slowly to disengage the plastic lock that holds the case to the phone. Remove the cover entirely once the lock has been disengaged.
5. Lift the LCD screen off the phone until the cable running from the screen to the phone's mainboard is visible. Disconnect the cable and remove the broken screen. Connect the cable to the replacement screen and then set the new screen onto the phone. Reattach the plastic cover. Flip the phone back over and reconnect all of the remaining pieces. Power your phone on and wait for the manufacturer's logo to appear on the screen to make sure the screen was installed correctly.
BEST OF LUCK
Lcd screen removal broken
just go to the company of the phone , and they will put a new one for you , im just suggesting so just search it. and good luck
Sep 20, 2013 | Nokia 6555 Cell Phone
How to switch on nokia 3120 when its on off switcher broken
remove the case and remove broken switch and solder a new one on. or replace the board sorry for that.
Dec 02, 2010 | Nokia 3120 Cellular Phone
My Nokia 6500 screen is broken and i need to copy contacts
Hi
It depends on where you have stored the contacts,if it is on your sim,you could remove your simcard and put it into another phone then you can get your contacts but if it is saved on the phone you would have to replace the screen of the phone before you could see your contacts.
All you need to do is to put off your phone,remove the battery and simcard then loose the phone with a phone screw driver,insert a plastic tool to seperate the screen from the motherboard,remove the old screen,be careful not to scratch or smudge the new screen.Then place the replacement screen back into the motherboard,then fix the front cover and couple back the phone.Enjoy your newly repaired screen.
BEST OF LUCK
Jun 27, 2010 | Cell Phones
My Nokia N72 screen is broken..............How much it cost for
Really sorry for the broken screen! Visit the Nokia Care center. I think the original screen should not go more than Rs.1500. Just check out.
thanks - billa
Sep 02, 2009 | Nokia Cell Phones
My mobile nokia 7610 has a broken display . can i replace it with a new display screen ?
I have nokia 7610 model, the display screen is broken.
How can I rectify that or what is the cost of display screen
Mar 01, 2009 | Nokia 7610
Lcd of nokia 6103
you can replace the broken LCD screen. Its an easy process. Go to ebay and purchase a replacement LCD Screen for your phone but make sure its a full replacement screen front an back. Then all you have to do is unscrew the the screes that are on the inside lid of the phone, take the front faceplate off, pop out the old and put in the new. Its easy
Jun 10, 2008 | Nokia 6103 Cellular Phone
Broken screen =(
Contact NOKIA Authorized sevice center nearest in ur area and they will remove the broken one and connect a brand new screen but first enquire abt the charges and stuff if ur mobile is not in warranty and even if it in warranty
Check whther u would be charged or not
Coz in many cases they dont charge u at all
But u might be charged as screen broke as it was not any problem that came with the phone ....
Dont go to any local engg to fix the problem, they might put a cheap or a fake screen which will work but they will not give u any waranty ...
VISIT http://www.nokia.com/
and check which is the nearest service center in ur locality
Feb 19, 2008 | Nokia 5300 Grey Cellular Phone
Can i change screen my self?
Remove the phone's fascia. Unscrew the 6 screws underneath. Lift the screen from the main body of the phone and replace with the new screen. Put the 6 screws back in
Dec 27, 2007 | Nokia 6120
LCD screen replacement Nokia 6300
Hey, Recently I broke the LCD display on my Nokia 6300. I couldn't find any info on disassembling it online so I decided to write my own guide. If anyone else wants it here is the PDF (with pictures). It is very simple to do and much cheaper than sending it away to be repaired. http://www.mediafire.com/?bslsvgvzj4c Cheers Roblo
Aug 13, 2007 | Nokia 6300 Cellular Phone
Cell Phones Logo
213 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
