Question about Westinghouse Washing Machines
The agitator on this machine only goes 1 way instead of back and forth. Does this indicate a transmission problem, or does the machine have a wash cycle where the agitator is supposed to go only 1 way, such as ''delicate'' cycle? There is no noise coming from the transmission and it goes into the spin cycle just as if everything is all right. The machine is labeled as Westinghouse, but all online posts indicate that it is a Frigidaire model #. The machine is about 15 years old.
  • denmanlach Jul 16, 2010
    This man does great work. Answer was timely and quite thorough. I will use your service again due to my experience today.
  • 6,784 Answers
HI. The internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement are driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely culprit is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
If possible, could you post the entire model number? This will allow me to pull up the necessary schematics and part numbers. Post the model number, asap.
Posted on Jul 15, 2010
  • 2 more comments
  • denmanlach Jul 15, 2010
    Hi localworker......very detailed answer, thanks.
    I'm doing this for my brother and he tells me that the model number is MWX433REW1
    Hope this helps.
  • Michael Masters
    Michael Masters Jul 15, 2010
    Thanks; One moment please..
  • Michael Masters
    OK, your unit is quite different. This is a clutch-less system(non-dual action agitator). This will be a more expensive fix, in this case. The agitator shaft of the transmission(gear case) is connected to the agitator. When the pulley of the transmission is turned clockwise, the gears inside the transmission cause the shaft to oscillate back and fourth. Simultaneously, the one-way bearing located at the base of the transmission, locks to prevent turning of the transmission and spin basket. The spin basket is fastened to the spin shaft of the transmission. When the pulley on the transmission is turned counter clockwise, a small spring inside the transmission tightens around the input shaft, thus, causing the transmission and spin basket to turn. Simultaneously, the one way bearing located at the base of the transmission slips to allow turning of the transmission and spin basket. Some how, that spring and one way bearing have failed. The spring in the gear case seems to be ok, but the bearing may be stripped or damaged. The one way bearing is the only part that cannot be replaced. Due to this inconvenience, you will need to replace the entire gear case. The reason for no trouble noises will be because all the gears are ok, this is a one way bearing issue. If this was a simple gear issue, it would be an easy fix, due to the fact that every gear is replaceable. Unfortunately, this is not the case.
    The necessary actions are to replace the entire gear case(transmission). The part number will be 5308057580R. Click on the part number to purchase.
  • Michael Masters
    Here is a cutaway of the gear assembly. All the gear and rod shaft part's you see are replaceable, but those replaceable parts are not your problem. The one way bearing located at the base of the transmission is what is causing the disruption in the assembly;Not allowing the agitator to free flow or oscillate. It is stuck, thus, not allowing the the oscillating motion. Possibly jammed, due the damage to its structure. The spin out will function correctly, but the agitation will only be in one direction.
Admiral washer aav7000aww-agitator only spins one direction-doesn't agitate-it stirs the laundry.
Remove the agitator, and turn the transmission pulley, one way, the spin basket will spin, the other way, the transmission spindle should go back and forth. If not, you have a bad transmission.
Here is the transmission to order if you should find it bad.
Sep 26, 2013 | Admiral AAV7000A
My washer works fine just no agition goes though cylces just fine fills and drians fine but agitator does not move
80040 dog kit is all you need. The upper portion of the agitator has four dogs mounted inside. As the transmission moves the agitator back and forth these dogs catch the side of the upper agitator. This rotates the fins and makes the clothes tumble on top of each other forcing them into a downward motion. When the facing of the agitator dogs wear smooth the upper agitator will cease to function.
Video:
I have a service manual and more videos HERE
Feb 10, 2011 | Kenmore 24032\24036 Top Load Washer
Agitator does NOT spin along w/ drum during spin cycle
If this is the old style that uses a belt, it is not worth fixing. But the problem sounds like the wig-wam is not functioning properly. Most of the time it was a wire broken since it moves back and forth constantly.
Jan 28, 2010 | Kenmore Washing Machines
I have a Kenmore automatic heay duty top load washer that when is in the wash cycle I believe what is the agitator only sort of jerks back and forth slowly instead of turning. It is a 90series and the...
see if you can lift agitator off and see if something is jammed under it ....like a sock or something..most unscrew at top and just lift off if this is not your problem it may be the transmission. how old is the washer if old probably cheaper to replace then to have transmission repaired(if it is transmission)
Jan 07, 2010 | Washing Machines
Adjitator is not turning or twisting
Hi
Thanks for using FixYa. If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Also, the inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the transmission spline.
If your socket is corroded then use 1/2" drive extension. This 1/2" is not the socket but the size of the square shaft the socket mounts onto.
This also happens usually when the motor is not lined up right on the peg wall, check if the motor clips are very hard to put back on. One or more of those little alignment pegs on the back of the motor are not seated in the hole.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Kenmore Washing Machines
I have a GE washer that will not agitate. The washer thinks it is agitating and goes through the cycle. The drum turns but the agitator doesn't. What could be wrong with it and how hard is it to fix?
Pull the agitator off and check the plastic block attached to the shaft top. Is it split or has sheared splines inside it? Remove the mounting screw to expose the shaft. Does it turn back and forth when it should be agitating? If no, possible transmission problems.
Jul 15, 2009 | Zanussi FJS1225W Front Load Washer
Agitator does not seem to be moving in the right direction
Yes, you will need to replace the transmission and clutch assembly. your assessment is correct.
Jul 11, 2009 | Washing Machines
Agitator not turning
If your washer doesn't agitate, check these:
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Mar 24, 2009 | Kenmore 22422 Top Load Washer
WWSR3090T2WW GE WASHER
http://www.repairclinic.com/0100_25.asp
Sep 08, 2008 | GE WBVH6240F Front Load Washer
Locks while agitating maytag a 208
its either the transmission itself or the upper bearing. most often its the transmission
Nov 20, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
90 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Harjeet Singh
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
