Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
How do you remove the top of Whirlpool Ultimate Care II.
  • 5,911 Answers
If you are referring to how to remove the exterior washer case on a Whirlpool manufactured top loader, the following link explains the procedure step-by-step:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
Read through the link provided and let me know if you have any questions. The procedure is much easier than it sounds.
If you require any further assistance, please post back with any symptoms you may be experiencing and let me know. I hope you find this information helpful.
Posted on Jul 15, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
    The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
    May 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    How to separate auger from agitator. whirlpool ultimate care II
    When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
    Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
    How do i remove the agitator on my whirlpool ultimate care II top loader washer
    first you remove the cap on top of the agitator then you remove the inner cap then you use a long extension with a 7/16 socket to remove the bolt the agitator will pull right up
    Sep 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    How do I take off Whirlpool Washer cabinet to get to the pump
    Go to;
    http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
    click on your model number. The new window will give diagrams in the left-hand side.
    Click on the diagrams. This will show the assembly of the unit. Use this as a guide for dis-assembly and re-assembly and do not mix-up parts as they are removed.
    Apr 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool "ultimate Care II" KSQ8511kQ0
    Having bleach spilled on the unit will hasten the process of rusting - it will eventually rust especially if in a wet humid setting
    Regards
    Sep 20, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II washing maching but will not spin.
    lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
    Dec 03, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    How to take the top off Ultimate Care II
    2 screws behind control to loosen control panel. when out panel will hinge back and you should see 2 clips that will pop off with a screwdriver and harness for lid switch. whole cabinet will then come off iff you pull it forward
    Oct 23, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    102 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
