Question about Gateway Essential 400 PC Desktop
I want a sound drive for my computer - Gateway Essential 400 PC Desktop
  • 146 Answers
You need to provide some more info, your model appears no where on the gateway support site
Posted on Jul 15, 2010
I have a WD 2500JB hard drive and I cannot get it to recognize the computer. Once I plug it into the computer....nothing.
Does the drive make any sounds, even a spinning up sound? Are you using it in an external case or just inside your computer?
Also, is this a drive you've been using and you have data on it, or is it a new drive?
Nov 20, 2011 | Western Digital Caviar WD2500JB Special...
My iomega hard drive worked fine before, but now won't show on My Computer or Autoplay. Help, please?!
First check whether your computer can see the external drive:
1. Right click My Computer and select Properties
2. Click on Device Manager
3. Expand Disk Drives by clicking the arrow on the left side of it.
Is the IOmega in the list of the disk drives?
If it is, then it is either:
1. The drive is faulty and the ID is from the IOmega controller
2. The drive is ok but severe bad sectors or other failing components prevent the drive to mount.
Testing the External Drive.
Listen closely to the if it sounds like it's spinning or it's doing something.
1. Clicking sound - The hard drive inside the Iomega caddy is faulty, either the pcb or heads, or both
2. Scraping sound - There is a platter damage on the drive. Recovery not possible.
3. No sound at all - Problem with either drive's pcb or the Iomega controller.
If your drive behaves like one above, I suggest you send your hard drive to data recovery companies.
May 06, 2011 | Iomega Professional 500 GB FireWire 400...
When I plug my Maxtor One Touch III into a USB drive, the computer does not recognize it. Why? The light on the One Touch button flashes when it is plugged into the computer. Also, the computer...
Do you hear the drive spinning up correctly? It should be a smooth sound with possibly a few ticks at first and then a steady humming sound. If you do not? No sound? Check the power supply: connected - check voltage with voltmeter if in doubt. Strange sounds or noisy sounds and then silence? The hard drive has failed. New drive? Check the Disk Management console in Windows and verify that the drive is partitioned and formatted instead of just empty unallocated space (the whole bar will be grey instead of navy in Disk Management). To access right-click "(My) Computer" > Manage. Select Disk Management from the left pane. If problem persists, check the "Device Manager" from the same window for devices with Yellow Exclamation marks. Try reconnected or reseating the cables.
Apr 14, 2011 | Maxtor OneTouch III Mini Edition 120GB...
1TB external hard drive has started to make load whirring and clicking noises that have not been heard before. It shuts down computer when connected so therefore cannot access files! The base serial no. is...
hi Ivandbafc.
this is what i have found out.
If your hard drive is displaying any of these symptoms it is important to stop using your drive immediately, Ongoing use of a drive with these symptoms will result in irrecoverable damage being caused to the media.
  • Hard drive producing a clicking sound.
  • Hard drive producing a clunking sounds.
  • Hard drive making buzzing sounds.
  • Hard drive making a grinding sound.
  • Its best you try and save all data to another drive asap.
Nov 27, 2017 | Buffalo Technology Computers & Internet
Lost sound...may have deleted sound max...tried to reload with realtek 97 ac, but, the PC does not recognize this hardware...
may be it's ur sound card driver problem, try to reload windows, if it doesn't work, install a pci sound card, it will work
Dec 19, 2010 | MPC Computers (9052701) PC Desktop
Computer won't recognize hard drive anymore
The clicking sounds and lack of response makes this sound like a dying hard drive to me, sorry to say.
I would try it on another computer if possible.
There are data retrieval experts but they tend to be expensive, files need to be quite important to make this worthwhile.
Apr 14, 2010 | IO Magic Corporation GigaBank (I250HD35)...
I have a smartdisk Fire Lite external harddrive - When I plug it into the usb hub the computer does not acknowledge it
Hello
If you power up the drive and you can feel that the drive is actually spinning, a periodic clicking noise is bad news.
Does the computer make a sound when you plug it in, or does it make a sound.
If the computer recognize when you plug it in, but it just not show in my computer, here is how you fix the problem. Go to:
control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below. Right click on it and choose the option to change drive letter or paths. Now just assign a new drive letter to the drive, restart your computer and it should work fine.
Best regards
Andrea
Nov 05, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
My Gateway used computer was working and now it won't boot-up and gives message that Hard drive connection is not good. The computer makes clicking or more of a tapping sound and now won't boot. thanks
It sounds like your hard drive has failed, IE.. the clicking/tapping sound. You could have the hard drive tested to be sure. You could swap out the hard drive to another machine and try it.
Jul 29, 2009 | Hitachi hts548080m9at00 80 GB Hard Drive
My computer dont have sound.For a m747 bx-pro
please install the sound drives in my computer
we have no sound drives in my coumpetr
i want sound drives with installing with my computer
Apr 06, 2009 | Computers & Internet
My computers hard drive makes a Buzzing noise
I would suggest you back up all your data as the hard drive appears to be failing. i presume you are certain it is coming from the hard drive and not a fan ?
Feb 21, 2009 | HP Computers & Internet
Computers & Internet Logo
18 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
