Question about Sharp AR-208D Printer
Toner seal sucked into machine
Toner seal left on, and sucked into machine. How do I get it out. It is deeper in the machine than the normal areas you can get to. Sharp AR-208D copier.
    Genius:
  • 1,121 Answers
Well you use a protective nose filter, these toner dust is can bleed nose if inhaled, and use a dust cleaner with a new bag, take the toner dust with a help a brush, clean all you can, then put all( bag and brush and nose filter, to contamined trash bin as dagerous to nature and heath), and put a new toner unit, and test.
Posted on Jul 15, 2010
F2 IS COMING
what is the sub code?
F2 is usually a toner issue and needs to be reset by a technician
the machine has blown the chip on the toner cartridge because it was unable to replenish toner in the developer unit
usually indicative of deeper issues inside the machine
Sep 16, 2013 | Sharp Office Equipment & Supplies
Jammed paper deeper inside of machine
Try removing the fuser to check inside of it and behind it for paper scraps. (Note: the fuser gets extremely hot, so make sure your printer is unplugged and cool before touching the fuser!)
Jun 06, 2008 | Brother MFC 9700 All-In-One Laser Printer
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
F2 while switching on
toner issue, machine has blown toner chip and needs replacing however it is a sighn of a deeper issue inside the machine because it is unable to replenish toner in developer and would blow every toner IC chip you put in that machine until it has been taken care of,
i suggest you take the machine to a technician
Aug 05, 2013 | Sharp Office Equipment & Supplies
Konicaminolta bizhub 600 machine dropping the toner. what is the solutions?
first toner must must and must be genuine, other wise it wont work in any conditions,
2nd toner density sensors and gamma sensor should be cleaned and all auto setting must be run .
third some time toner drops down the others side of the drum due to recycle clutch did't not work properly and all cleaned toner drops down after filled in recycle area,
Jan 11, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Chest type freezer has frost on left side at the top of the freezer
leaking seal at that point,feel the seal around that area you will feel it warm.This is caused by warm air getting sucked in at this point,replace seal.adrian?????????
Mar 15, 2011 | Magic Chef Freezers
SHARP AR-287 F2-00 error code
Although this appears to be an ATC (automatic toner control) problem and it may list as such in service manual which gives brief description of error code it is often something else.
There is a sponge roller at bottom of toner that wears down considerably and when the hopper is very low or out of toner the otner light will come on(triangle of dots). The customer puts the new toner in and the sudden surge of a large amount of toner cascading into the hopper causes an excessive amount of toner to go past the sponge roller and directly into the developer unit which is directly under toner hopper.
The ATC sensor is on the bottom of developing unit and "reads" the density of the developer /toner ratio and with a very overtoned situation as the one created above you would get an F2-00 code.
What is normally done is to either dump toner out of hopper and replace sponge roller and seals or replace toner hoppers as a whole which is quicker and costs almost rh same as cahnging the sponge roller and seals is more labor intensive.
Also the developer is now contaminated with an excessive amount of toner and the recommende solutin is to replace the developer and calibrate theu service program.
This is hardley recommended by a service man unfamiliar with this mode let alone the customer. I ahve been in the Bay Ridge area for years and as a matter of fact bought an investment property thru Petses Realty. Frank
May 26, 2009 | Sharp AR-235 Copier
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Illegal toner
The HL2700CN is a Tally machine rebadged by a number of manufacturers.  Each has it's own unique 'plug' on the back left side of the cartridge as you look at it in the machine.  Check that the plug is the right shape and if necessary fit the one from your empty 'brother' cartridge.
I have only ever had the 'illegal toner' message when I put in a Lexmark cartridge by mistake - swapping plugs solved it.
'Brother' machines seem to run at a different temperature than other Tally clones - so there may be a deeper problem with the toner that you used.  In my case it simply failed to fuse to the paper and I had to get another cartridge.  Check for deposits on the OPC belt and fuser rollers.
May 03, 2008 | Brother HL 2700CN Laser Printer
Color too light
Non genuine toner usually is cause, but there area few others but in the majority(90%) of cases people reporting this problem have be found to be using aftermarket toners.
Please mark as fixya or reply to dig deeper.
S.
Dec 14, 2007 | Brother HL 1440 Laser Printer
Sharp AR-208D Printer Logo
82 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
