Question about Maytag MLE2000 Front Load Stacked Washer / Dryer
WILL NOT REACH FULL SPIN CYCLE, loud hum prior to spin, starts to spin, hits second speed but will not kick into full speed.
  • 4 Answers
I would suspect that you have a Motor and Motor Control Problem. This washer has a three phase motor in it and it could have one phase out of it or the Motor Control board could be bad. However it is recommended that you replace both at the same time with a motor conversion kit.
Posted on Aug 16, 2010
Motor starts spinning but why does it then seem to "stutter" and not reach top speed?
one of two things, this is a newer machine and it doesn't work the same way as the older machines and ramp up to full spin speed, Everything is plastic for gears so they have to get much of the water out they can before hitting full speed. or second the belt is slipping. You didn't leave a model so I to a guess to how the machine really is.
Mar 28, 2016 | Maytag Washing Machines
After spin cycle clothes r still soaking wet. cleaned coin catcher. ideas???
If the spin cycle is kicking in, then you can be pretty sure that the water has all emptied from the drain cycle, otherwise it wouldn't start the spin. So the chances are the coin catcher clean was not going to be the fix. The Highest probability is simply a case of overload. If the load is to great and the balance is thrown off as a result then it won't get up to full speed (the motor has several windings, so it slowly steps up from a slow spin, then up a step, then another, then full speed. poor loads will cause it to fail to kick in the fastest spin. Having said this, if that's not the case, then I'm afraid to say you may well have a motor, or a controller module fault. If so, it could get expensive.
To test, run the shortest cycle you can with the machine empty. It will be a lot easier to hear and see this way. Make sure that you hear the empty pump eject the water and that you then hear it runn on a little after all the wayer is gone. This will show if it IS in fact enptying completely. Presuming it is, now watch and listen as the spin kicks in. Does it reach full speed when there is no load? If it does, then check the weight of your DRY load doesn't exceed the recommended load (remember a pound over weight will be several pounds overweight once wet!). If it doesn't get up to full speed with no clothes in it, I'm afraid its time to call an engineer.
Feb 09, 2011 | Washing Machines
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Spin cycle slow unless hose lowered
you will have to take the hoses off the pump and clean the pump out its probably got sand in it
Apr 23, 2009 | Washing Machines
Maytag neptune frot load will not reach full spin speed.
It will not spin while washing, it's more of a rocking back and forth. As far as the spin cycle. If it's not reaching full speed I bet you'll notice that it's not doing the full cycle because the load is bouncing around and cause the washer to shut off. take some of the clothes out and watch it spin the water out.
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Washer will drain but will not reach full spin in spin only mode
they dont spin full speed if they are overloaded, try it with less clothes.
Feb 11, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Maytag PAV2000
Its possible that the machine is not reaching full speed during spin. Check to see if the belt is slipping and that the thrust bearing pulley turns freely. When in the spin cycle the thrust bearing compresses the brake directly above it. If this brake is hanging up even a little the machine cannot reach full speed. The diagram on the right shows the thrust bearing assy. and brake.754307c.gif
Jan 14, 2008 | Maytag Performa PAV2200
Loud clicking during spin, won't spin full speed
manofred, you either have something in your pump or the coupler is starting to break up. Tip the washer back and take a look. See if there is a bunch of black debris under the trans. If so, your coupler is failing. The pump will come off with 2 clips and 2 clamps. Check to see if something is in the impeller. Check the attachments....Catriver...post back.
Feb 13, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag MLE2000 Front Load Stacked Washer / Dryer Logo
130 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
