Scanner error 5 is the message when i put on my printer hp laser jet 2840
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 123 Answers
Unfortunatly I have seen many HP units with Scanner Error 5 . This is usualy caused by a problem in the formatter (mainboard) or scanner assembly. There is nothing you can do to recover it. If the printer is still under warranty you will need to call HP ( 1 800 334 51 44) or take the printer to an athorized warranty depot in your area. This link will help.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
You can contact me directly on : eliteprintersolutions@hp.com
Posted on Jul 15, 2010
I have an HP 2840 color laser jet that keeps presenting a Scanner Error Code 6. Might anyone know if and how I can repair this on my own? Thanks a ton! Mike
replace optical scanner assembly..(a unit located in flat bed scanner with florocent lamp moving left to right while scanninf & copying)
Sep 17, 2011 | HP LaserJet 2840 All-In-One Printer
I am getting scanner error 5 massage on hp 2840
A tech needs to look at it. It could be as easy as just reseating the 4 wire bundle connector that comes off the scanner and connects to the formatter.
But, in any event a tech has to check it out.
Jul 29, 2010 | HP LaserJet 2840 Printer
2840 Hp Color laser jet displaying Scanner error 05
The book says to try the old power off and on. And then replace the scanner assembly and then the formatter.
Personally, I would try the formatter.
Sep 26, 2009 | HP LaserJet 2840 All-In-One Printer
I am getting a an error message 5 on my hp printer model number 2840. please help
HP 2840 error message 5
Scanner Assy needs to be replaced, go to HP site for parts.
Aug 20, 2009 | Office Equipment & Supplies
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Apr 16, 2008 | HP LaserJet 2840 All-In-One Printer
HP laser Jet 2840
Try using a different Memory card and see if it reads it, if not you might need to replace the memory card reader.
Oct 26, 2007 | HP LaserJet 2840 Printer
77 people viewed this question
jasbo
jasbo
