Question is for welcomejee. Hi im Tom the guy with the 6 blinking light not working sony grand wega 72" tv. I replaced the g1 board as proposed and still have 6 blinking lights. What could be my next possible thing to do. Is there anything else that would cause the 6 blinker to do so?
  • 10,594 Answers
Hi again,
As I said its problem of +17V and -17V that foes to audio output section of tv and these volts supplied from G1 (power board).
http://www.fixya.com/support/t5290453-kdf_70xbr950_lightning_storm
Since G1 board has been replaced but tv still shows 6 blinks error that means audio output section has problem and most probably audio output chip is bad and causing shut down of +/- 17V supply lines.
Do you have multimeter and can measure volts in tv circuit board?
Thanks.
Posted on Jul 15, 2010
  • 2 more comments
  • tomplows Jul 15, 2010
    afraid I dont have that and wouldnt know what to do with it if I did. Sounds like this one goes over my head. Should I just replace it and if so is there a part number or should I call a repair man and if so any suggestions in my area Mokena ILL
  • Shahid Electronics
    Shahid Electronics Jul 15, 2010
    OK, there is simple test, unplug connector CN1624 on G1 board that provides voltage supply to audio output ICs on A board. Turn On tv and it should turn On if audio output ICs are cause of problem.
    If tv still gives 6 blinks error then its serious matter because next suspected board is C1 board and its complicated. TV repairman is needed to replace it.
    Let me know your findings please to move ahead.
    thanks jee. I pulled the plug u instructed it was red in color. Still have 6 blinks. I will look for a repair man. At least we probably have it narrowed down for him. Thanks for the help.
    I'm sorry for that thunder storm that caused C1 board damage. TV technician will fix it for you.
    Thanks.
Standby light is blinking 6 times
There is a board G1 and from that board there is low B which is 6v if missing then it will blink 6 times please check that voltage
Apr 14, 2014 | Sony Televison & Video
How do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking...
Good day!!!
6 blinks its the clear indication that you have bad power supply board..
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Nov 20, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
TV quit working when watching it, power light flashes red six times when trying to power on?
6 times blinking red light shows problem of missing DD 6Volts in G1 (power supply) board.
Please replace G1 board in tv to solve this problem, part number of G1 board is as follows..
A1060177A
Thanks.
Feb 05, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv won't turn on...light flashes red 6 times
According to Sony's diagnostic chart, a six blink code means the plus/minus 17 volt line is not being supplied from the G1 board. (The Power Supply). I would replace the G1 board and that should fix your problem.
I hope this helps,
Skyassoc
Dec 15, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
KDF-60WF655
this means replace the G1 board part # A-1060-177-A. some of these boards are not componet level repaired
Jan 20, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA 50 or 60 inch, 6 blinking lights
Hi, you can find that info & buy the parts here, www.wehaveparts.com good luck it`s not an easy job take pictures if you have a digital camera, BMW Rider
Jan 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
the g1 board is your issue. 6 blinks means there is no or low b+ coming from the g1 board.
Oct 08, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
