Question about Northstar Explorer 557 GPS Receiver
What is the Explorer 557 yellow connector pinout
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
What is the pin layout for the rs232 connector on the F5U409v1 adapter from belkin.
The pinouts are in numerical order
1 2 3 4 5
6 7 8 9
Pin signals:
1.Data Carrier detect
2.Rx
3.Tx
4.Data Terminal Ready
5.Signal Ground
6.Data Set Ready
7.Request to Send
8.Clear to Send
9.Ring Indicator
Dec 20, 2010 | Computers & Internet
How to crimp 1 end of cat 5e cable with rj11 connector that was cut off. What is pinout order that each wire should in the rj11 connector? the colors are: Black,green,red, yellow & clear. ...
The pinout of the modular camera connections is as follows:
Pin 1 ----------------------- Alarm / In
Pin 2 -------------------- +15Vdc Out
Pin 3 ---------- Intercom Audio Out
Pin 4 ------------------------- Video In
Pin 5 ------------ Intercom Audio In
Pin 6 -------------------------- Ground
Goodluck
Oct 18, 2010 | Cameras
Model D3057F3H Want to use it to power a car radio. What is the on / off connection and what is the 12V out let than can handle 5amp
Check the label on the power supply for the current rating on 12 volts.
The +12 volt is the yellow colored wire and the black is the ground.
To turn on the switch mode power supply connect pin 14 (for a 20pin connector) or pin 18 (for a 24pin connector) to ground.
You can use a switch so you can turn the power supply ON and OFF.
Please click on this link for diagrams of the 20 and 24 connector pinouts :-
http://pinouts.ru/Power/atxpower_pinout.shtml
http://pinouts.ru/Power/atx_v2_pinout.shtml
Sep 12, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
VGA connector on a Dell e770s 17 inch monitor has been cut. Need to know where the wires go on a 15 pin db connector?? Can anyone help...Thanks gvp
Found out the information thru this page. Its a diagram of the 15 pin VGA Pinout and where the pins are supposed to go and what there fuctions are, hope this helps. Page is courtesy of pinouts.ru
http://pinouts.ru/Video/VGA15_pinout.shtml
Aug 29, 2009 | Computers & Internet
Cable end chopped off need to know pinout mapping to reattach a new cable end to attach to computer.
All VGA connectors use the same pinout. Here's a link that shows you the VGA Pinout,
http://www.interfacebus.com/Design_VGA_PinOuts.html
More monitor pinouts,
http://www.montest.com/technote.html
Apr 21, 2009 | KDS K717s 17" LCD Monitor
Plenio vxa-2000 antenna pinout
If you are looking at the external connection end with it in a "V" position, on the right - the upper one is green & the lower one is red. On the left - the upper one is yellow & the lower one is black (or the big bunch of copper wires). Be sure you are reconnecting an exact pin set up - an s-video is not the same (unfortunately). If you found a replacement antenna or a correct replacement part, please let me know where. I have to repair mine too.
Oct 27, 2008 | Digital Video Systems Plenio VXA-2000 GPS...
Northstar Explorer 557 GPS Receiver Logo
85 people viewed this question
Top Northstar GPS Experts
Marvin
Marvin
Jose Ma DM.
Jose Ma DM.
Are you a Northstar GPS Expert? Answer questions, earn points and help others
