Question about KitchenAid KBLO36FMX Bottom Freezer Refrigerator
I have a KitchenAid bottom mount built-in refrigerator. It started beeping this morning and the displays for freezer and refrigerator would flash. Now the beeping is gone and the displays are not working. What is wrong?
  • Kelly
    Kelly Jul 15, 2010
    Are any of the fans running? Compressor running? Or is the unit completley dead? See caution below!!!!! Remove J2 connector from the main board. Check for resistance between the white wire and red wire on harness Is the resistance approximately 1.5K ohms to 3K ohms? Condenser fan OK! Measure the resistance directly at the Condenser fan motor! Is the resistance approximatelty 1.5K ohms to 3K ohms? Yes fan motor is electrically ok No =0pen Fan Motor Winding Does the condenser fan motor read open? Does the condenser fan motor read shorted ( below 1K ohm of short to motor case?) Replace the condenser fan motor Check for voltage at main board J2. Is there at least 12VDC between pins 3 - 5 and between 3 - 8? Yes= main board OK Condensor motor stalled ! Repair or replace condenser motor. Check voltage at main board J2. Is there at least 12VDC between pins 3 and 5 ? Yes is good! No=Replace main board and the condenser fan motor Caution: Unplug power when disconnecting and connecting connectors on the board. I am not posting this as a solution due to the lack of information as to what is working or not working. This is my best "how to" at the moment. If you need more information or provide more symptoms I can most likely provide more assistance. Thanks for choosing FixYa. Kelly
  • Kelly
    Kelly Jul 16, 2010
    Additionally if you would please provide the model number so I can ensure we are troubleshooting via the correct model.
    Kelly
SOURCE: all lights went out in my refrigerator/freezer
I have this side by side Viking- The worst product I ever bought. Nothing but problems. If I can give anyone advise do not buy one.
Posted on Mar 10, 2008
localwonder
  • 6784 Answers
SOURCE: Kitchenaid built in refrigerator controls are beeping
Sounds like a water flow issue. Check to make sure your manifold is getting proper water flow.
Posted on Feb 14, 2009
  • 5 Answers
SOURCE: My KitchenAid KBRS22K bottom mount refrigerator is
the problem here is the defrost element is not coming on, the problem is the control board in the fresh food compartment is defective and not telling the element to defrost. Therefore your cooling coils are impacted with ice which keeps freezer cold, and sensor in freezer says everything is ok and therefore sends nothing to refrigerator. Replace the defrost control board, Thaw out the cooling coils in freezer, and your back in business
Posted on May 20, 2009
  • 28 Answers
SOURCE: New Kitchenaid refrigerator often makes sharp bang noise.
I have an old Amana bottom freezer that does that. It's because the defrost heaters are doing their job and the area around them as well as the coil is expanding rapidly. Try making certain that the cabinet is level and not on an unsteady footing. You might want to try turning the T stat in the freezer to a lower setting. Usually between 2 1/2 and 3 1/2 works best in all freezers. If none of this helps and the banging continues, get used to it or get another fridge. It seems to be a failing in bottom freezer models for some reason. It's harmless but annoying. I actually know someone who says she has the ghost of a frozen turkey stuck in her freezer that's trying to get out! LOL!
Posted on Jul 09, 2009
  • 7 Answers
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Posted on Oct 09, 2009
The freezer section of my refrig has a LOT of "snow". Any fix?
KitchenAid KBRS19KTMS Owner Manual
see page 16, moisture buildup
consider:
draw not closing tightly enough or not closing all the way
bad gasket allowing moist air into freezer compartment
defective defrost cycle
Aug 14, 2015 | KitchenAid Kitchen Aid - KBRS19KTMS...
F&p beeping,pressed green button beeping stoped but now fridge and freezer not cooling greenlights flashing?
HI,IF YOUR REFRIGERATOR IS BUILT WITH DIGITAL TEMP CONTROL ,PROBABLY THE PROBLEM COULD BE A BAD SENSOR ,BAD COMPRESSOR,OR BAD CONTROL BOARD,IF YOUR FRIGE IS LESS THEN A YEAR OLD MAY BE UNDER WARRANTY ,CONTACT THE FACTORY TECH DEPARTMENT FOR DIANOST AND SERVICE..
Feb 21, 2011 | Fisher and Paykel Active Smart E522B...
The temperature control lights going on and off. Plus there is a beeping sound. So far it's still cold but I just noticed it this morning.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 19, 2010 | KitchenAid KBRO36FMX Bottom Freezer...
Viking Refrigerator stopped cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 12, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
Might be an ice cube stuck in the ejector. Hit it with a hair dryer.
Feb 14, 2009 | KitchenAid KSSC48QMS Side by Side...
Freezer temperature display keeps flashing
on the main circuit board on top of the fridge is a button with "test" on it. hold that in for a few sec, it should start beeping at you. push it again and it will beep again, do this about 4 time till it goes quite. this may fix it but the reason for it is prob your sensor is covered in ice, you need to leave it off with the doors open. there are 2 drain pipes at the back of the fridge ( bottom ) defrost it till no more water comes out of these, when you think its done, leave it for a few more hours and if any water comes out your not defrosted yet--- mine took almost 3 days.
Jul 29, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
KitchenAid KBLO36FMX Bottom Freezer Refrigerator Logo
81 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
