Question about HP Compaq nc6220 Notebook
Will not load past starting screen (HP logo)
Started up computer and it will not load past the starting screen, freezes. Then when trying to run windows xp recovery disc to see if it is a problem with the programing, but freezes when I try to run the program.
    Genius:
  • 1,121 Answers
Maybe is hard disk problem, try boot from cd.(check for any errors dispayed)
Posted on Jul 15, 2010
Hi i have a coolpad avail 3300 and when i turn it on it doesn't go past the coolpad logo it stays stuck on that screen what do I do
Coolpad Arise locked on startup screen : perktv - Reddit
https://www.reddit.com/.../coolpad_arise_locked_on_startup_scree...
RedditApr 21, 2015 - The community doesn't take too kindly to it either. ... charged battery, or on just the power cord, but it will not go past the "Coolpad Arise" logo.
Coolpad 3300A wont go past the start screen where it says ...
www.askmefast.com > Computers & Internet > Security > Screen
Coolpad 3300a wont go past the start screen where it says coolpad? ... Coolpad won t go past start up screen ... Software for avail coolpad 3300a phone ..... Can i get a new 4g coolpad for mertopcs if part of the screen doesn`t really ... coolpad phone model 3300a always freezing at the coolpad logo and how to unfreeze it?
Jan 01, 2016 | Computers & Internet
Cant flash bios a1410n
Try simple first. When booting, AND BEFORE the XP logo, press f8 repeatedly until you see the boot options menu. If you miss it, you will see the xp loading logo, if so, restart and try again. From the boot menu, try the "boot with last known good configuration" option. If that doesn't fix it, re-boot, f8, and try the "safe mode" option. If it boots with any of these methods, do a full shut down and re-start again normally.
If that doesn't get it to boot normally, I would do the following. (I would, but you should only try this if you have a good understanding of windows and needed programs installing, ram replacement, hard drive repair/replacement and internal computer wiring)
Now, if your computer worked fine, then suddenly started this loop, I dont think it a bios problem. I expect you might have a hardware problem. Did you change any hardware very recently? Sometimes that stops windows from loading. Or, you could try changing the ram and retry, could be bad ram. But I think it is a hard drive issue. I think you will have to reload windows and/or replace the hard drive.
To safeguard your info, you should replace the main hard drive with another drive, load windows fully on it, then add the original drive back in as a slave/secondary drive, and retreive your personal info and files from it. Your needed programs will have to be re-installed on the newer windows drive. When you get all your files copied over (use copy and paste, not cut and paste), you can format the old drive and use it as storage, or just format and keep for the next time, or sell it. I would also run a "drive fitness program" to test it for bad sectors.
Or, if you dont need anything from your windows, you could format and install from the xp install cd. If it loads and runs, the drive is probably ok (I would still test it for bad sectors), or, if it cant load because of errors, the drive is probably bad. Retry with a new drive.
Jul 16, 2013 | HP Pavilion a1410n (ER890AA) PC Desktop
My hp g56 laptop freezes at hp logo
Cause by hardware error. try to refix all connection inside. and then try.
Dec 30, 2012 | HP Computers & Internet
My HP iPAQ HW6910 keeps freezing. Sometimes it loads up to the main screen and then freezes after about 30 seconds, other times it gets as far as the windows loading screen and then most of the time it...
HP iPAQ week, wow.
let me guess , hp has no support now in this old thing and you need help.question 1: why use this thing,question 2, how much will you spend on this worthless broken thing? or buy parts, or batteries for it or 3 how much labor on such and old thing is warranted.?
May 29, 2017 | HP iPAQ hw6910 Smartphone
HP Pavilion ZE2000 shuts down after HP Logo Screen
try putting a virus scanner boot disk or its because of mabey your laptop needs a new bios chip mabey?
Dec 31, 2009 | HP Pavilion ze2000 Notebook
I have an hp Laptop DV3515ee works fine. One day i started it up and it shows me the manufacture logo at boot up and shows the Microsoft boot Screen Looks fine from that point. after the boot screen ends...
The problem could be a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Nov 16, 2009 | HP Pavilion Laptop
NEW ACER ONE NETBOOK WILL NOT BOOT UP
Try Safe Mode.Disconnect every device (Mouse also)
Hit F8 at very beginning until you get a list of options select Safe mode and check if Windows starts.
then try step by step confirmation option.
say yes to every request until freeze: last driver you accepted to load is the culprit.
Remove it in Safe mode using Start/Run/Msconfig
Dec 26, 2008 | Computers & Internet
Xbox 360 elite freezing
I'm having the same issue with my elite... almost looks as if it glitches ( vid card possibly ) sometimes it will make it to loading screen of any game others it wont even make it past the xbox logo.. If I'm lucky I can get to the dash board, but most of the time it just freezes.
I'm so glad I spent the money on an elite cause my premium I sent back to MS 3x still red rings.
Any suggestions...? All lights turn green like normal no red ring o death yet .... yet, and I'm so close to tossing this thing off the deck and calling it a day.
Thanks for any help you can give
Aug 25, 2008 | Microsoft Xbox 360 Console
My cell phone keeps Freezing and now it won't Get past the starting screen with the alltel logo on it
have you tried takign out the batery while its on and putting it back in? Did it get wet or something? what happend to it that it started doing that?
May 31, 2008 | Cell Phones
HP Compaq nc6220 Notebook Logo
309 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
