Question about HP OfficeJet 7310 All-In-One InkJet Printer
Remove and Check Color Cartridge keeps appearing. I have changed color cartridge and message still appears.
    Genius:
  • 1,121 Answers
Is a non-original or defect color cartridge. ask for change cartridge to original. If still continues, ask for a new printer the cartridge bruned your printer board.
Posted on Jul 15, 2010
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
Cyan color cartridge "appear to
http://h10032.www1.hp.com/ctg/Manual/c00485555.pdf
Apr 22, 2011 | HP Photosmart 3210 All-In-One InkJet...
Dell 720 won't print color, color ink cartridge missing
check to see if the color cartridge has the plastic tab on the cartridge. Remove and reinsert cartridge.
Sep 13, 2009 | Dell Inkjet 720 Printer
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
"Remove and check color cartidge."
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
Mar 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Remove and checl color cartridge
The problem most likely is with the electrical contact between the color cartridge and print carriage. Even if you've replaced the cartridge, if the contacts on the carriage are still dirty, it won't make a good connection with the new cartridge and the error message will still appear.
Fortunately, the HP web site has a solution posted at the following link:
Cleaning Cartridge and Print Carriage Contacts
Good luck.
Sep 04, 2008 | HP PSC 1610 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP PSC 750 PROBLEM
    Had the same problem. Cleaned the copper-colored "contacts" on the actual printer. Where the printer and the cartridge touch ... you will see them when you take the cartridge out. Hope that helps.
    Feb 17, 2008 | HP PSC 750 All-In-One InkJet Printer
    Changing cartridges
    I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
    I just used it yesterday, what is wrong???
    Nov 06, 2007 | HP PSC 750 All-In-One InkJet Printer
    HP OfficeJet 7310 All-In-One InkJet Printer Logo
    283 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
