Question about Linksys Wireless-G Broadband Router
I need to reconfigure my Linksys WRT546 router
I need to reconfigure my Linksys WRT54G router after AT&T changed the network password on my modem-they won't connect. The ATT guy said I need to create the PPPOE connection in the router. Is this something I can do?
  • 2,005 Answers
Go to 192.168.1.1 on the internet; this page will allow you to configure your router. the username is: admin the password is: admin
Posted on Jul 15, 2010
How did my linksys router's ssid change when i got a new modem
I haven't a clue? Reset the device to default settings and reconfigure. Use this procedure, if you need it, to reconfigure, update the firmware if applicable: http://support.linksys.com/en-us/support/routers/WRT54G AND this: http://www.columbia.edu/acis/networks/aptnet/linksys/
Apr 01, 2013 | Linksys Wireless-G WRT54G Router
Access linksys wireless-g wrt54g with Nook tablet
Change the wireless network name and then change the key.
Try to connect to the new wireless network and see if that works.
If not then you can try to upgrade the firmware of your Linksys router.
After upgrading the firmware, reset the router and reconfigure it.
Jan 01, 2012 | Linksys Wireless-G WRT54G Router
My son went to youtube and found a video on how to change WPA to WEP. Now my network is not working on my printer and laptop
you need to reconfigure your printer and laptop to WEP but I don't recommend it as WEP is terrible and easy to crack.
connect to your router via cat 5
open internet explorer and browse to http://192.168.1.1
login with the default login is blank. pass is admin.
go to wireless and to wireless security.
change it back to WPA personal.
change the passphase for the wireless password.
use the new passphase you created and tell your printer/laptop to join your wireless network
you may want to change your wireless password too so your son won't reconfigure your router again.
do this by going to administration and change the password there.
Apr 03, 2011 | Linksys Wireless-G WRT54G Router
I have no wepkey to network the problem is anyone can browse connecting to my network using wi-fi
  • If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
    To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
    Once your router is hard reset, you will need to login and reconfigure it again.
    To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
    LinkSys Default Password
    On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
    Once you are past the login screen, you are able to reconfigure the LinkSys router.
    You want to go to the management tab and change the administrator password to something else to keep others from accessing your router.
  • 3
    After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
    Good luck
  • Mar 12, 2011 | Linksys Wireless-G Broadband Router
    Can not attach my Ipad 3G to my linkys wrt546 router.
    Does your Ipad have WiFi capability? If your Ipad has only 3G capability then you can only access internet through your cellular service(i.e. at&t, verizon, t-mobile, etc.) provider with a data plan. In order to attach your Ipad to the linksys wrt546 router your Ipad must have WiFi capability
    Oct 12, 2010 | Linksys Wireless-G WRT54G Router
    I need to secure the network from my router ....how do i do this?
  • To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
  • After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
  • Oct 11, 2010 | Linksys Wireless-G Broadband Router
    I cannot link my my Ipod to my router. What must
    Make sure that the wireless network key which you are punching is right,If it's WEP key,then try putting a dollar "$" sign before you give the WEP key.
    In order to re-check the wireless network key of your router,follow following steps:
    1> By default ip address of all linksys router is 192.168.1.1.Open the internet browser & clear address bar at the top completely & type default gateway of yours computer which you are getting from router
    2> Default username is blank & password is "admin".Otherwise give router password.Again if it is not working type default password which you usually give to your computers
    3> Finally,you will be on router setup page;in top click on Wireless tab --> Wireless Security
    4> Here you can re-check that your wireless network password.
    If u need technical help in order to do the above changes in router have a words with linksys technical suppoprt.
    Dec 08, 2009 | Linksys Wireless-G WRT54G Router
    Need to reset my password and user name as for some reason neither is working...I have tried to put them both in a million times...It is a linksys wrt546
    hello: you have to reset the router by pressing small hole with balpoint for a few sec. connect router with a network cable and then you have to go to your browser and type the ip adres 192.168.1.1 a paswoord request sreen wil appear leave the user name blank and enter the default paswoord ADMIN in lowercase letters, for addind security you sould later set a new paswoord using the administraion tools management screen of the web based utility then click on ok button
    and cofigure your router with your stuff
    Oct 18, 2009 | Linksys Wireless-G WRT54G Router
    I forgot my password
    Sep 08, 2009 | Linksys Wireless-G WRT54G Router
    Can see the wireless network, but can not find the password to log on.
    Do you know how to access your linksys router? Do you know the password on the linksys router?
    If not you will need to reset the linksys to restore the password to it's default and then reconfigure the router from scratch.
    To reset the router use a ballpoint pen end press 10 seconds on the reset button in the back (ATTENTION: YOU WILL NEED TO RECONFIGURE THE ROUTER)
    Once you reset it the password to access the router is admin. Connect to the router using a cat5 cable, point your browser to : http://192.168.1.1
    leave the user field empty and type admin in the password field.
    You can now go ahead and reconfigure it.
    Jan 21, 2009 | Linksys Wireless-G WRT54G Router
    Linksys Wireless-G Broadband Router Logo
    194 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
