Hi, I have a Philips 42PFP5332D/32 42" TV. I noticed A LOT of people on here are having the same problems that I'm having. Overall I noticed two solutions being given. 1. Replace Power supply (could cost about $150) 2. Take it to repair center (cost could be $500+) and 3. Replace capacitors ( 10$ bucks) I want to go for the cheapest solution, but I don't even know what a capacitor is. Could someone help me with this? How to find a dead capacitor. Buying the correct replacement, how to install it, tools needed, and how not to get electrocuted. Or does anyone have a website that explains how to do this? I'm a pretty decent DIY type of guy, and routinely work on computers, building them from scratch. I just need a little help with repairing a tv since I never done it before though. Thanks.
  • romefitforba Jul 15, 2010
    Wow thanks for the quick reply. I think I'll give it a shot. Worst case scenario is that I won't have a TV, the same scenario I'm in now lol.
    Thanks again.
  • 484 Answers
The problem to the television could be related to any of the three (3) solutions that was given to the people with the problem. And the prices also vary as well.
Firstly, the capacitor is a battery like structures that are upright or slant on the panel of the television. They are found on the panel. Their function is to regulate the current that flows through a panel.
To find a dead capacitor, firstly some might have swollen, some with burnt looking edge, and you can test it with a meter reader by locating its tip under the panel and testing it with a meter reader.
To buy a replacement capacitor, you need to remove the old one by turning to the back of the panel, locate the capacitor to be replaced pins and burn out the lead that is on it with a pin tip soldering iron, be very careful in order not to damage any other component on the panel.
Tools required: Soldering iron, cutting pliers, replacement capacitor.
In order for you not to get electrocuted, ensure you do not plug the television to any power supply when working on it.
I can only direct you to www.youtube.com where you can see videos of how capacitors are replaced. You can search for 'how to repair a samsung tv with power problem' a list of videos will come up and you can select that which best suits your taste.
You can do it yourself. But make sure you are very careful when doing this.
Take care and good luck
Posted on Jul 15, 2010
Tv will not turn on. Makes on going clicking sound only.
http://www.shopjimmy.com/philips-996500042146-power-supply-unit.htm That is the most likely cause of your problem.
Aug 25, 2015 | Philips 42PFL5332D 42 in. LCD Television
How do you find the power board for the Plasma TV Phillip Model Number 42PFP5332D/37
Carefully remove the back of the TV. If you have a grounding strap, wear it. If not, always keep one hand on the TV and use the other hand when ''rooting around'' back there to prevent shock damage. The power supply will be large, and very heavy. Here is a link to what it could look like - this link is a list of all possible power supplies in your model along with photos. http://www.shopjimmy.com/catalogsearch/result/?q=42PFP5332D+power
Once you find the power supply, locate a part number on a sticker or the board itself and match that up to one of the power supplies from the link. Leave the power supply inside the TV until you have the replacement in your hot little hands, so you can remember how it went in etc.
Jul 08, 2011 | Philips 42PFP5332D 42 in. Plasma...
Where is the power supply on model #42pfp5332d/37?
Hi
You can obtain service documents for this TV from
https://www.manualsparadise.com/ShowProductsForModel.do?model=M53646572
I do not have the service manual for this Plasma TV myself, but it is not difficult to locate the power supply inside the TV, follow the power cord, when it goes into a board, you know that is the board, most likely has high voltage components 400V and similar, you can't miss it.
Don't touch what you don't need to touch, you might shock yourself or in worst case, injure yourself or get killed.
NEVER OPEN A UNIT WHILE ITS PLUGGED IN; UNPLUG AND LET THE SET SIT FOR AT LEAST A HOUR. and even then, the components - capacitors may hold even deadly voltages.
Dec 09, 2009 | Philips 42PFP5332D 42 in. Plasma...
I need 42 philips tv manual
Try a web search for "instruction manuals". There are many available.
Jun 11, 2009 | Philips 42PFP5332D 42 in. Plasma...
Crack on the inside screen of my 42" Philips Plasma TV
This is a known problem with Philips. If you keep on them they will work with you. Another option is call a repair shop in your area and see if they can help you out. Sometimes a repair shop will help out if you allow them to do the service if they are able to get Philips to pay for the repair.
Good Luck
Apr 21, 2009 | Philips 42PFP5332D 42 in. Plasma...
Philips 42PFP5332D 42 in random clicking problem
EVERY TIME I HAVE SEEN THIS PROBLEM IT HAS ALWAYS BEEN THE SMPS...SWITCHMODE POWER SUPPLY CIRCUIT BOARD...THATS WERE THE NOISE IS COMING FROM...RELAYS ON THAT BOARD ARE BEING ENERGIZED WHEN THEY ARE NOT SUPPOSED TO...THE UNIT SHOULD REMAIN IN STANDBY MODE UNTIL AN ON COMMAND IS RECEIVED VIA THE REMOTE CONTROL OR SET POWER ON BUTTON...TRY REPLACING THE SMPS..JOEACE
Jun 06, 2008 | Philips 42PFP5332D 42 in. Plasma...
Firmware update
This TV has the ability to upgrade firmware from any standard USB thumb-drive. Here is a link to the Philp's site that has the instructions as well as the link to download the newest firmware:
http://www.usasupport.philips.com/consumer/productDocuments.html?ProductCode=42PFP5332D/37&subCat=PLASMA_LARGE_32_42_SU_US_CONSUMER
Jan 20, 2008 | Philips 42PFP5332D 42 in. Plasma...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
