Question about Amana ABB1927DE Bottom Freezer Refrigerator
Fridg is not cooling.frezer working real good.
Fridge is not cooling.frezer working real good. bottom mount frezer
  • Anonymous Mar 28, 2014
    will not stay cool all the time
  • 478 Answers
Open the freezer compartment and listen for the fan motor if you don't hear it but you can hear the compressor running. youll need to first make sure that the door switch is working( If the lights go off when you press the button it should be okay). You'll need to remove the back panel and inspect the coils if frosted over evenly and the fan still is not working give the fan a little push. if it will not go, you need to see if it has voltage if so, replace the fan. If no check the defrost terminator which only on amanas will keep the fan off. In this case replace the defrost terminator(it look about like 5 quarters, with 2 wires clipped through the evaprator coils in back of freezer.
Posted on Jul 15, 2010
Do you have the problem of the fridge part not working and instead spoiling your food? i just had to throw away chicken breast that i love pork chops and an expensive steak from costco and the temperature is set to 7
Posted on Oct 12, 2010
  • just ed Dec 10, 2010
    Just happened to me with my Amana (freezer on the bottome). Root cause was the back of the freezer had turned into a block of ice (probably because we left the door hand open an inch a couple nights over the last year and frosted it over). The freezer vents cold air, with the help of a fan) to the fridge part. Look at the back wall of your freezer, there should be some vent holes in the sheet metal that allow the fan to grab cold air. If they're completely iced over, that's your problem. I took the freezer area apart (bigger deal than it sounds). Took the drawer off, unscrewed the door rails and removed, took the ice maker completely out, took the sheet metal covering the entire back wall out. Once exposed I saw the freezer coils and fins completely blocked with ice. An hour with a hair dryer and a bunch of towels did the trick. While in there I checked that the fan was working and it was. If it won't spin when the unit is turned on then that's your problem. Defrosting like this will produce a lot of water that will get all over your floor, be prepared. There is a condensation pan in the back of the fridge that will overflow and it will slosh around while moving the fridge in an out. Your other option, if you have another cold place to put your food, is to just unplug the fridge, leave the doors open and wait 48-ish hours. Again, water all over your floor.
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
Fridge not cooling .kenmore trio frezer works fine
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Oct 06, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Frezer work refrigerator is warm on top
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 05, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Fridge/frezer not cold,only at the bottom,act like fan that blows across coils is not working,how do I fix
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 04, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Frezer not freezin fridge not cooling
try to change the clickson and relay on the compressor and if it still doing that there are two problems to look for or a blokage in the system or the compressor are broken
May 13, 2009 | Maytag Appliances Magic Chef 18 cu. ft....
Frezer cold and working but the refrigerator
It sounds like your fridge has leaked refrigerant gas. The leak needs to be repaired and then the fridge should be recharged.
Mar 02, 2009 | Refrigerators
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I called a repair man. I was charged $150.00 . It was the box at the botom left side of the fridge,under fridge. It's fixed .It took about 5min. to replace it. I could have done it my self. Reading FixYa pointed me in the right direction. Reading postings on FixYa! What a great place to recieve info! I am not sure what the part cost, if you were to install it your self. Not a big job it has two screws that holds it in place. I had to work, was in a bind for repair man. It was worth the $150.00 to have my food back in the fridge.
Jan 17, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Amana ABB1927DE Bottom Freezer Refrigerator Logo
861 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
