Question about Linksys Wireless-N WRT150N Router
Remote Access I have a Linksys WRT150N router using cable (comcast) Internet access. The modem is bridged. The router is providing the static ip info. The facility has internet access. The facility has no inbound access to the router management interface or the applications running on hosts. I see no attempts to log in on the router logs.
    Problem Solver:
  • 8 Answers
IF you are getting public ip from your isp, please go to administrator tab of the router and first change the router's password which is on the top on same page in black dots,,type your new password by deleting old one and re-confirm it just below and save it..router will prompt for the new password just to let you know settings are saved now enable remote managment option on the same page and port is 8080(default, you can use your own port number) and save setting..now you are ready to access your router remotely for that note down the public ip you are getting on your router's status page and in remote location you need to type something like :- http://x.x.x.x:8080...x.x.x.x is your internet ip (public) and 8080 is port number for remote management.
For host applications need to know which application you are running according to that need to open port in the router using Port Forwarding feature of the router.
Posted on Jul 23, 2010
Need help setting up the Sudenlink Modem to Linksys Router
Connect lan cable from modem to linksys router's WAN port.
Then configure linksys router with below method.
Yes you need wireless router to use wifi in ipod touch or on laptop.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method.
Then click on WAN settings set as your internet service provider settings like static ip address.If service provider give you user and password for connect internet then set router in pppoe mode.
Enable DHCP.
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 18, 2011 | Linksys WRT160N Wireless Router
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
I've connected the cat 5 wire from my cable modem to the linksys cable router with 8 ports but it does not give access to the internet on the other computers that are networked. If I let it find an...
hey, you need to create bridge between your cable modem and router and you need to give one static IP in the router. kindly note you need to keep cable modem and router in the same class eg-( cable modem ip is 192.168.1.2 then router should be the same range.) and provide gateway of your ISP in the router.
Jun 09, 2009 | Arris SURFboard SB5120 Modem
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Router Question
hello!
-- what is the brand of your modem? have you tried connecting your computer directly to the modem and check if you can get online? If yes, Internet connection is fine and the problem is on the router if not, call your ISP first and check your connectivity with them.
-- have you tried connecting your computer directly to the router without connecting the modem to the router and check if you can access the router setup page? there are some cases where in the modem and the router have same IP address that's why you cant access the setup page of the router because of IP Conflict. Try to access the router page , router not connected to the modem only on the computer and change the LAN IP address of the router to 192.168.2.1. Connect the modem to the router and try again to shut down everything and power on the devices one by one and check if you can get online.
-- if after changing the LAN IP address still doesnt work, try to check if you can access the router page by the new IP Address. Make sure that you do not have other firewall or any security enabled on the pc. If yes, try to enable the MAC Address clone on the router and check again the internet connection. Try to configure the router with a diff computer also help isolate the problem
-- if after that and it still not working last option is to upgrade the firmware of the router. possible that there is a problem with the router and upgrading the firmware normally fix internal problem. If that still doesnt work, the router is defective.
Aug 29, 2008 | Linksys Wireless-N WRT150N Router
Connecting to internet
Ok, cable (coax) comes in from wall and attaches to modem. Ethernet cable goes from modem to WAN Port of router. You may have to reboot both devices to ensure that your modem (internet service provider) assigns IP address to your router. If PC is close enough, attach new ethernet cable from one of the 4 ports on your router down to your PC's ethernet adapter. (where your modem used to plug into). Router will now assign an IP address to your PC and you should be able to access the www.
Good Luck and let me know if you have any more questions.
Jul 13, 2008 | Linksys Wireless-G Broadband Router
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Cannot access internet through WRT150N router wirelessly OR wired
Same problem here, the motorolla surf board works way better. It also coult be your ISP.
Apr 02, 2008 | Linksys Wireless-N WRT150N Router
Siemens S765IP w/ router linksys wrt150n
What VoIP provider are you using?
Try connecting router directly to the modem and the laptop to the router and see if your laptop can get out onto the internet. If you cannot, then your router might not be handing out IPs to the devices on the internal network. You can enable the DHCP server on the router using the administrative web interface at http://192.168.1.1.
If you can get out onto the internet with your laptop behind your router then look at defining a DHCP reservation on your router for your VoIP phone and then forwarding the following to your phone:
5061 UDP
5060 UDP
10000-20000 UDP
These are common ports amonst the VoIP providers.
Hope this works, if not we'll give it another shot.
Jan 30, 2008 | Linksys Wireless-N WRT150N Router
How can I establish a bridge with WRTSL54GS Router?
To bridge yoyr router.. contact your dsl internet service provider (isp) and ask then to brigde your modem.. and get the exact user name and passwd.. and config your router for a pppoe mode and that will fix your problem..
Dec 05, 2007 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-N WRT150N Router Logo
249 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
