Question about Acer Aspire 9810 Notebook
How do I remove acer aspire 9810 keyboard,I have removed the base cover and screen assembly but I cant fugure out how to remove the keyboard Thanks in advance Peter
  • 942 Answers
To remove the keyboard, remove the screws at the back of your laptop. Then remove the Hard drive, then remove the Optical drive then remove the video card, and then power supply. Then remove the fan from the motherboard and you may remove the screws on top of the keyboard. Finally you may replace the keyboard.
Posted on Jul 15, 2010
HOW TO GET THE BACK OFF
Break it off..........
In order to take the Base Enclosure (Bottom Cover) off, you would have to break it off.
The Acer Aspire 5000 series of Notebook PC's, disassembles from the Top down. When you are done you are looking at an empty Base Enclosure,
http://www.ebay.com/itm/ACER-ASPIRE-3000-3004-ZL5-5000-LAPTOP-BOTTOM-CASE-COVER-LOWER-BASE-3AZL5BATN05-/181127078788
You have to;
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Harddrive Compartment Cover, Harddrive, Memory Compartment Cover, Ram Memory, Wireless Module, Wireless Antenna wires out of laptop body, Optical Disk Drive, (DVD drive), Display Assembly, (LCD Module), Keyboard Cover, Keyboard, Palm Rest Cover, Motherboard, and so on..........
Then you have the Base Enclosure. (Bottom Cover)
WEAR an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Acer Aspire 5000 series of Notebook PC > Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the paragraph that starts with Aspire 1200. (1200 in Blue)
Drop down to the 6th line (4920G), scroll across; and click on the blue -> 5000
For additional questions please post in a Comment.
Regards,
joecoolvette
May 02, 2013 | Acer Aspire 5000 Notebook
Acer Aspire 7735Z - how do you take the keyboard out?
Acer 7735Z
Carefully, Flip over the laptop with the lid closed (and at your knees), and remove the 3 across the top, then the middle one to the right of battery compartment, and the 2 to the left of the battery compartment.
Open the laptop, and lift the cover gently that houses the power button. Don't lift it right off as there is a cable connecting it to the laptop & you don't want to disconnect it. You can, but you don't have to.
Then, lift the keyboard up at the top of the assembly, carefully as you till need to take note of the direction the keyboard cable goes into the laptop. Pry up the brown cable retainer for the keyboard cable (it will swivel up 90 degrees), slide out the cable and remove the old keyboard assembly.
To install, put in cable, push back the cable retainer, slide keyboard assembly into laptop bottom first (you will see the tabs and where they fit). Replace the cover that houses the power button, it will snap down to help hold the top of the keyboard down. Close cover, flip over and replace the screws.
Jan 09, 2010 | Acer Aspire 4720 Notebook
I like to know how to remove the keyboard for my acer 5050 laptop?
Hi there.
Push the screen back
Lift up the keyboard bezel using a small flat-head screwdriver.
Continue removing the bezel with your fingers.
Lift up and remove the keyboard bezel.
Remove two screws securing the keyboard.
Lift up the keyboard and place it on the laptop cover so you can access the keyboard cable connector.
Unlock the connector and pull the cable.
Remove the keyboard.
Good luck and thanks for choosing FixYa!!
Jul 14, 2009 | Acer Aspire 5050-3242 Notebook
Acer Aspire 1640z overheating
Clear the dust from the heatsink and fan assembly. Most laptops have vents on the bottom and outlet vents on the side or back of the laptop. The fan covers on the base are held in place by screws. The fan is usually over the CPU and is held in place with 3 or 4 spring loaded screws, remove these will allow you to remove the fan and heatsink assmbly.
If there isn't vents on the bottom of the laptop, only on the sides and back edges, then the heatsink and fan assembly is usually located under the keyboard and you need to remove the keyboard to clean/remove the dust off the heatsink/fan.
After cleaning and before re-assembly apply a thin film of heatsink compound on top of the CPU.
Feb 21, 2009 | Acer Aspire 1640Z Notebook
How to replace keyboard on Acer Aspire 5570 notebook
remove two screws on the back of the laptop where the screen opens and close. then open the cover and use a flathead screw driver to pick the top portion of the keyboard screen. unscrew two more screws and u can slide the keyboard out.
Sep 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 1640z keyboard removal
I don't have the diagram but i can give you direction.
1. remove the power cover first (where power button is), it might have 3 screw that hold, if there is 3 screw on the power cover, remove it first.
2. after your removed the power cover, you can see the screw that hold keyboard. remove that screw and you can remove the keyboard.
Jul 30, 2008 | Acer Aspire 1640Z Notebook
Acer aspire 3000
There are 3 screw behind the laptop, on the back of the screen hinges. Remove them then open the laptop, and with your finger nails, lift the power cover closest to the screen, it will then raise and you will be able to remove the keyboard.
Jul 26, 2008 | Acer Aspire 3000 Notebook
Have acer notebook aspire 1410 cant get case appart
remove all visable screws on bottom of pc,remove battery and covers remaining screws are hidden in such places,remove screws at back behind screen to lift front panel and access keyboard removal.depending on model access to panel with mouse pad is done after keyboard lifted.
Mar 08, 2008 | Computers & Internet
Acer Aspire 9810 Notebook Logo
464 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
