Question about Linksys Wireless-N WRT150N Router
I have a LInksys WRT150N Router. The modem is bridged. The router is providing the static ip info. The facility has internet access. The facility has no inbound access to the router management interface or the applications running on hosts. I see no attempts to log in on the router logs.
2 Suggested Answers
  • 8 Answers
SOURCE: Remote Access
IF you are getting public ip from your isp, please go to administrator tab of the router and first change the router's password which is on the top on same page in black dots,,type your new password by deleting old one and re-confirm it just below and save it..router will prompt for the new password just to let you know settings are saved now enable remote managment option on the same page and port is 8080(default, you can use your own port number) and save setting..now you are ready to access your router remotely for that note down the public ip you are getting on your router's status page and in remote location you need to type something like :- http://x.x.x.x:8080...x.x.x.x is your internet ip (public) and 8080 is port number for remote management.
For host applications need to know which application you are running according to that need to open port in the router using Port Forwarding feature of the router.
Posted on Jul 23, 2010
Remote Access
Jul 15, 2010 | Linksys Wireless-N WRT150N Router
I am having trouble setting up my WRT150N
Try to place the modem in bridged mode
Then run the setup wizard
It should work
Else configure the details Manually on the router
Sep 26, 2009 | Linksys Wireless-N WRT150N Router
I am installing my new wrt150n router and no internet
Turn off modem and router. Connect router to computer. Turn router on. Connect router to modem. Power up modem. When it discovers the modem it will assign to it the new IP address.
Hope it helps.
Sep 25, 2009 | Linksys Wireless-N WRT150N Router
Problem with RV042 linksys router
Ah Wan 2 doesnt like to receive a DHCP address you will have to get static Ip addresses
Jul 11, 2009 | Linksys RV042 VPN Router
Cant connect to the internet with linksys wrt160nv2
if this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
Jun 12, 2009 | Linksys WRT160N Wireless Router
I've connected the cat 5 wire from my cable modem to the linksys cable router with 8 ports but it does not give access to the internet on the other computers that are networked. If I let it find an...
hey, you need to create bridge between your cable modem and router and you need to give one static IP in the router. kindly note you need to keep cable modem and router in the same class eg-( cable modem ip is 192.168.1.2 then router should be the same range.) and provide gateway of your ISP in the router.
Jun 09, 2009 | Arris SURFboard SB5120 Modem
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Cannot access internet through WRT150N router wirelessly OR wired
Same problem here, the motorolla surf board works way better. It also coult be your ISP.
Apr 02, 2008 | Linksys Wireless-N WRT150N Router
Siemens S765IP w/ router linksys wrt150n
What VoIP provider are you using?
Try connecting router directly to the modem and the laptop to the router and see if your laptop can get out onto the internet. If you cannot, then your router might not be handing out IPs to the devices on the internal network. You can enable the DHCP server on the router using the administrative web interface at http://192.168.1.1.
If you can get out onto the internet with your laptop behind your router then look at defining a DHCP reservation on your router for your VoIP phone and then forwarding the following to your phone:
5061 UDP
5060 UDP
10000-20000 UDP
These are common ports amonst the VoIP providers.
Hope this works, if not we'll give it another shot.
Jan 30, 2008 | Linksys Wireless-N WRT150N Router
How can I establish a bridge with WRTSL54GS Router?
To bridge yoyr router.. contact your dsl internet service provider (isp) and ask then to brigde your modem.. and get the exact user name and passwd.. and config your router for a pppoe mode and that will fix your problem..
Dec 05, 2007 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-N WRT150N Router Logo
48 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
