Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My ScanDisk was working fine in a 7 port hub earlier today. I removed it because I thought I would need to use it on another computer and then realized I wouldn't need to. So then I put it back into the same port as before and noticed it didn't light up and I couldn't find the drive on my computer. I then tried several other ports both on the hub, my computer and a 2nd computer and it just appears it's dead. I also noticed that when I took it out the 1st time and when I reinserted it, it felt very warm to the touch. Please help, I have a lot of valuable (to me) info on this drive and I need it right away. Thanks, Kris
  • 621 Answers
Sounds like it is dead sorry to say flash drives are really not a very reliable backup source should always copy to DVD also. Another thing in future you should always use the safely remove hardware option in the bottom right taskbar to remove power from any device before you unplug it. Cheers from Scott please dont forget to vote
Posted on Jul 16, 2010
My computer does not recognise simpletech 250GB HDD drive when connected. The lights glow only. Earlier I had used this on my TV. Could it be that the system got corrupted
Buy an external USB hub that has an AC power adapter.
Your computer is not providing enough power to spin up the drive.
A self powered hub will provide the necessary power. 7 Port USB 2 0 HUB AC Adapter Monoprice com
Mar 10, 2015 | SimpleTech SimpleDrive 250GB 3.5" USB 2.0...
Just bought an Ativa 7 port USB 2.0 Hub and don't know how to connect it to my computer. No manual came with it.
The ones that I have seen have 7 ports 5 in back 2 on top these are called Type A USB ports, to the left of the back ports the power port is there. To the right, there is a smaller port usually a USB Mini B or Micro A port that is where the small end plugs into and the Type A on the cable goes to your computer.
Jan 12, 2013 | Computers & Internet
My plasma TV is not getting a signal from the hdmi cables. They worked earlier today and I have not changed them. The game system is the only component functioning now.
Tries tv unplug,replug it back like about hour later.For the tv do a resetting itself,take out the tv HDMI cable out the old HDMI hub port try plug it into another tv HDMI hub port.Should work now,still have same problems,probally needed a new HDMI cable replacement,the old HDMI cable is worn out or shorted out.
May 08, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
My OS is Windows Vista Home Premium edition. Will Belkinns 2.0 x 7 port hub F5U237v1 will work with it?
Yes it will definitely work it no matter what operating system your computer is using it will be working fine.
Nov 25, 2010 | Belkin (F5U237) 7-Port USB Hub
Unable to download pictures
I do know that sometimes a usb port will fail, for whatever reason, to recognize a device. It's happened to me before, and you can try a couple things. First, unplug and plug the usb port back in while it's connected to the camera. If the computer fails to recognize it, try you different usb ports, and the computer may respond. Aside from that, if you're running the XP or later versions of windows, you might try restoring your computer to a time before this problem occurred. Also, an update to Windows could have adversely caused this to happen, and restoring to an earlier date would hopefully reset the usb software's ability to recognize the port. Perhaps someone else will have suggestions if none of these things work, but that's the limit of my dealings with this problem. There's always the possibility that a hardware issue is at work here, but I hope not. If you do discover the port is bad, you can always get a hub and deal with it that way, leaving it connected to a known, good usb port. Just make sure you get a hub that is aided by a power source to relieve the computer from the burdon of powering up the hub. Good luck.
Apr 03, 2010 | Canon Cameras
My computer does not recognise my Belkin 7 port hub.
sometimes the power it gets from pc fails but if it is powered alone check outlet or strip
Oct 04, 2009 | Belkin (F5U237) 7-Port USB Hub
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
Overheating
We had a GE 7 port usb port and it overheated and melted----thank goodness I got up when I did or the house would have caught on fire. The only thing we had connected to the usb port was a APC battery backup unit. Any reason why the usb port overheated?
It was pugged into the battery backup unit and I am hesitant to rehook the computer up to the battery backup unit and also will not by another GE usb hub again and whatever hub we do use, I will not plug it into an outlet!
the computer was downstairs and I noticed the odor of electrical burning smell upstairs---the unit was bought nov 25, 2007 and we returned it to BJ'S for a refund today-----I do not reccomend this product to anyone.
Oct 29, 2007 | GE JASCO (HO97878) 4-Port USB Hub
Problem with SXP2224WM compex switch.
If I remember correctly, this device has vlan. Did you check to make sure that the vlan is configured or turned off? And does this have a firewall? Seems like a firewall is blocking ping port but allowing traffic. Also, I thought the 24WM was a 24 port switch, you mentioned a hub, but what kind of hub is it? It really sounds like a port blocking issue.
Jun 17, 2007 | Compex (sxp2224wm) Networking Switch
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
