Question about Kenmore 24032\24036 Top Load Washer
Wont rinse the machiine will not rinse, hear a noise coming from the control knob but it will not since or spin?
  • Kenmore Master
  • 2,699 Answers
If it won't spin you could have a broken lid switch or a broken motor coupling.lift the lid up around two inches and close it a few times,if you don't hear the switch clicking the lid switch is broke and needs to be replaced.if that seems ok i would check the motor coupling,take out the two screws that hold down the top console,flip the console up,unplug the lid switch harness in the middle or a little to the right of the middle and with a screw driver pop the two metal clips,one on the right and one on left side of top and then you can remove the frame of the washer.on the bottom remove the two clips on the pump and move the pump out of the way,now take out the two screws and pop the two clips and remove the motor,on the back of the motor you'll see the coupling,the other half is on the tranny,if any of the six arms that interlock with the rubber piece are broken that's your problem.one more thing,you say it won't rinse allwashers rinse with cold water the water valve could be humming and not letting any water come in,i just don't understand what you're asking about that.next time send the model number and let me know if any of this helps.good luck
Posted on Jul 16, 2010
Recalibrate the WTW4950XW0Q
Instructions should have come with control take the knob and spin left about 5 clicks to clear rotate knob 3 clicks clockwise 1 click counterclockwise 1 click clock all within 8 seconds all lights should light up rotate knob till rinse light lit press start
Jan 06, 2015 | Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
GE washer wont rinse, drain or spin. Makes buzzing noise
You didn't say which model it is, but by now I assume you know about the small trap at the bottom of the newer ones? On 2007 and back, you have to remove 3 or 4 screws on the bottom panel. You'll see the rubber stopper screwed in.
Have a pan under it capable of holding at least a quart of water. There will be all kinds of stuff in there.
If that isn't it, you may have a bad control panel.
May 12, 2009 | Washing Machines
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
GE Front Loader Washer
Door latch is sending false signal to control board,first replace the door latch.
May 26, 2008 | GE WSXH208A Front Load Washer
Washing machine making a clicking noise.
The problem most likely is something stuck in the water port of the drain pump. My machiine would not empty once and I found a 12 penny nail that had made its way from the drum though the drain line to the the pump, where it was wedged against the impellers that spins to draw out the water through the pump. The pump is located in the front right bottom of the machine and accessible by reoving the lower front panel, It is held in place by 4 small screws and is connected to the drain lines. Disconnect the plug for the outlet, then disconnect the power connection from the pump. Disconnect the drainlines after removing as much water possible from the drum as the water will come out of these liines when you remove them. Remove the pump, open the cover to see the impeller and hopefully the bobby pin, nail, screw, or whatever else is stuck there will be visible and easily removed. Put the pump cover back on, replace the drain lines and screws, and reconnect the power connection to the pump. Then do a better job checking your pockets.
Sep 01, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
52 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
