Question about Dewalt Drills
What is the equivalent in power to a 24volt cordless drill in a corded drill?
  • 2,176 Answers
I really dont think there is one. the corded drill will usually always have more power than a battery one.
Posted on Jul 18, 2010
Tip
How to use an Electric Drill
  • First You need to choose which kind of electric drill you are going to use - the cord or cordless. The one who has a cord attached might limit you because it need to have an outlet.although, it powerful then the cordless drill. On the other hand, the cordless drill can be use anywhere without needing an outlet.
  • Choose the wright drill according to your job. For an heavy-duty project purchase a more powerful drill but remember that it run slower and most of them have a cord attached to them. If you have lightweight jobs so you can use a cordless drill.
  • The safest way to use a drill is to make sure that the materials to are drilling are straight ahead of you or down below you. in additional, in case that the materials you are drilling is hard or thick one, in first use a hole punch to start the hole before the drill.
  • When you starting the job, push the drill slightly. start out slowly, and as the hole progresses, increase the speed slightly.
on Aug 27, 2008 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Radio will not work on battery but battery runs drill.
What is the relationship of the drill, radio, and battery? Is it a rechargeable battery for a cordless drill, or what? You are leaving out a lot a details here. Perhaps the voltage and polarity of the battery is correct for the drill but not the radio.
Jan 23, 2016 | Drills
Do I need to put oil in a brand new Titan 24volt impact wrench
I have never used that brand of impact, but I have used many others and I have never known an electric impact or drill to need oil. You need oil in an air powered impact because the air motor needs lubrication. The electric motors in electric impacts have sealed bearings and brushes that are meant to run dry. The actual impact assembly should be sealed as well, it should not need any oil.
Jul 13, 2012 | Titan 24v Cordless Impact Wrench
The charger is broken,doesnt work.
Generally chargers are considered replacement only items. They consist of the box, the power cord, and a printed circuit card, which generally cannot be repaired if something has burned out, etc. About the only repair that can be done is replacing the cord if it is faulty.
Apr 13, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
How to apply an electric drill? how to used the electric drill?
Please follow the below steps to use a electric drill -
1. Determine which electric drill is best for you, the cord or cordless. The electric drill that has a cord attached needs to have an outlet which might limit you according to what job you are doing. The cordless drill is limitless and can be used anywhere without needing an outlet. Corded drills can be more powerful, where cordless drills are limited to power and can sometimes be a bit bulky.
2. Consider most of the jobs you may use an electric drill for. If you have a lot of heavy-duty projects ahead, you might want to purchase a more powerful drill. They run slower but have the power behind them to get the job done efficiently. The more powerful drills usually have a cord attached to them. If you have a lot of lightweight jobs to use a drill for, then a cordless one may be your best selection.
3. Arrange the work to be drilled either straight ahead of you or down below you. These are the two safest ways to use a drill. The drill is also more secure and won't waver while using it. If the material you are drilling is a hard or thick material, use a hole punch to start the hole before you drill.
4. Push the drill slightly as you are drilling to give a bit of added force. Start out slowly, and as the hole progresses, increase the speed slightly.
Tip -
Secure your work before drilling by using clamps. The more powerful the drill, the slower it drills. The less powerful the drill, the faster it drills.
Warning -
If you are using a cordless drill, charge the power pack before starting a job. Keep the air vents on the drill clean, and clear of any debris so the drill does not overheat.
Good Luck!!
Thanks
Sep 29, 2009 | Black & Decker Grinders
Looking for Craftsman Cordless Screwdriver Charging cord
Go to the following link:
http://commercial.searspartsdirect.com/partsdirect/parts/5102970-17/0009/900&pathTaken=partSearch&filterPart=&pop=flush
Sep 12, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Need to replace power cord to battery charger of cordless drill
it takes a 24V DC 200mA  The one I have is a Ktec Model KA12D240020034U
Aug 29, 2009 | Coleman Drills
Delta cordless drill
I would use any 12VDC adapter that has no more than 200mA output. Keep an eye on it. It should be nearly charged within 10 hours. But watch to make sure that niether the battery or the adapter gets too hot. The adapter will get warm, but should never be too warm to touch.
Apr 13, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
Drills Logo
47 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
