Question about Panasonic KX-TGA650B (037988474806) Cordless Expansion Handset
How do I delete 1 of the handset from the base
3 Suggested Answers
SOURCE: deleting messages from handset
Not usually. I recently purchased a new (refurbished) base station and cannot get it to talk to the handsets
Posted on Sep 08, 2008
  • 6 Answers
SOURCE: KX-TG1000N new handset 1
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Posted on Dec 21, 2008
    E4 - Erros My uniden phone model TRU 9485 - 4WX after outage power, now on LCD screen appear E4 and it didn't respond to any button when i press. I read some help which they say press 3 button...
    Hello
    Connect the phone line and power UP the base unit. Place the handset on base to get charged. It must reset automatically when you place the handset on base to charge. If not; resetting both handset and base unit is necessary.
    Resetting the Handset
    You may need to reset your handset in the following instances:
    You lose a handset and purchase a new one. When you try and register to your existing base you get registration
    failure.
    You are unable to register any handsets to the base.
    You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
    to the base, the handsets say #3 and #4, but you only have 2 handsets.
    When you are instructed to by the one of the manufacturer's call center representatives.
    To reset, do the following:
    Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
    WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
    DEREGISTER HS appears. Select YES, and press the OK soft key.
    ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
    handset will clear its registration information from the base, and then delete its own base information.
    MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER'S MANUAL. To
    re-register the handset to the base (see page 25).
    If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
    base and the base is connected to power.
    Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
    will be erased. For more information on resetting the handset back to factory settings and when you need to
    do this, see www.uniden.com or call our Customer Service Hotline. See back cover page for contact information.
    Resetting the Handset without the Base
    If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
    reset the handset and use it with another base.
    Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
    BASE UNAVAILABLE appears.
    Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
    appears.
    Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
    will delete its own base information without trying to contact the base. When the base information is deleted,
    the handset displays MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER
    TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
    OK.
    Sep 12, 2011 | Uniden TRU9485 Cordless Phone
    Phone are 5.8 ghz vtech
    may be the frequency problem for noise problem.
    pleaSE CHECK IT OUT.
    ADJUST THEM AT SOME PROPER LEVEL..
    AND THEN TRY.
    Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
    I have uniden cordless phone model dxa15588-2, how do I register handset on base?
    1-Press the hangup key (represented by a red phone) and the "#" key at the same time for at least five seconds.
    2-Select "Deregister hs." Choose the handset and press the "Select" key (which also shows an envelope for messages).
    3- Choose "Yes" to confirm deregistration. The phone clears its registration information from the base and deletes the link from its memory. The message "Handset not registered -- place handset on base to register. See owner's manual for help" now shows on the display. If you are out of range of the base, "Out of range" shows.
    4-Place the handset in the base charging cradle. The phone automatically selects a new security code from those stored in the base.
    5-Make sure your phone is working again after "Registration Complete" shows on the display
    Hope this will Help. Thank you for using Fixya !!!
    Nov 17, 2010 | Uniden Cordless Phone
    Vtech 6.0 deregister
    Getting startedReplace a handsetIf you want to replace a handset or reassign the designated handset numberof a registered handset, you must deregister all the handsets and thenindividually register each handset.To make deregistration easier, read all of the instructions on this page beforeyou begin. To deregister all handsets:Press and hold FIND HANDSET on the telephone base for about 101.seconds (until the IN USE light on the telephone base turns on and starts toflash), then release FIND HANDSET.Press and release FIND HANDSET again. You must press FIND HANDSET2.while the IN USE light is still flashing. The IN USE light flashes forapproximately seven seconds.All system handsets show CONNECTING... The deregistration process3.takes about 10 seconds to complete. All handsets show NOT REGISTEREDwhen the deregistration completes.If deregistration fails, you might need to reset the telephone and try again.To reset:1.Pick up the registered handset and then press talk/flash.Press OFF/CLEAR and place the handset back in the telephone base.2.-OR-1.Unplug the power from the telephone base, then plug it back in.You cannot deregister a handset if any system handset is in use.
    May 29, 2010 | Vtech Cordless 6041 Phone
    Can not rec a dial tone, phone states no link to base move closer
    If “No link to base. Move closer to base, try again.” is displayed
    even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
    • Make sure the base unit is not being used.
    • Have both handsets and base unit nearby during registration.
    • Follow steps 1–3 listed below. You have about 1 minute to complete them.
    • Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
    If you re-register the handset using the other handset’s extension number, the other handset will not function.
    • If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
    • You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
    1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
    • The CHARGE indicator flashes.
    2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
    handset which has lost the communication.
    3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
    • When registration is complete, a beep sounds from the handset and the display shows the number.
    • Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
    Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
    How to remove Uniden handset from base
    The brillian people at Uniden don't feel it necessary to provide this type information in their manuals. You have to trial and error to find it, but what can you do. All you have to do to reset the base unit itself is to unplug the power, then while holding down the delete key, plug it back in. Hold the delete button down until you hear a beep, which indicates it has reset. Now you can readd handsets and they will start at 1.
    Mar 08, 2009 | Uniden TCX905 Cordless Expansion Handset
    Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
    The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
    Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
    To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
    However, the base will still have this handset in it’s record.
    To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
    However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
    Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
    Aug 21, 2008 | Lands Phones
    No ring on handset
    It may have lost the link to the base unit. Make a note of all the personal details, stored number, etc., then reset the handset. Do this by pressing the spanner button until the display changes, then press and hold the 'R' (delete) button until the handset resets. You'll have to set it up again, but at least it will link.
    Spanner then 1 for ringtone, CID for volume.
    Spanner then 2 for keypad bleep, 1=off, 2=on.
    both cases press spanner to confirm changes.
    Jun 28, 2007 | NTL VS1500 Cordless Phone
    Verge cordless phone system v581tad
    I believe you have the expansion capacity of the phone all used up. The phone cannot register any more handsets until you delete the handset registered that is not in use. First check the handsets and see what handset numbers they carry. It should be #1,#2,#3,and #4 if it does not then you will have to delete the one that is missing or if it is then delete handset #5.To do this you will have to use one of the handsets registered to the base. First Press the MENU/ OK button then scroll down to ADV,SETTING then Press MENU/OK then scroll down to DEREGISTER then Press MENU/OK. Then ENTER HANDSET PIN would show, if you have not changed the pin enter 0000 if you have enter your pin member. From the next options select HANDSET and press MENU/OK from the next set of options select the handset number you want to DEREGISTER and press MENU/OK from the next option select YES then MENU/OK. Then try to reregister the new handset To do this Press the MENU/OK button then go to ADVANCE SETTING press MENU.OK scroll to REGISTER then press MENU/OK Select the base number displayed then press MENU/OK. PLEASE WAIT will appear. Then from the base press and hold the PAGE button until the handset prompts you to ENTER PIN # .Enter 0000 OR your pin number then you will see PLEASE WAIT. A tone will confirm the handset registration.
    Apr 03, 2007 | Uniden Cordless Phone
    Panasonic KX-TGA650B (037988474806) Cordless Expansion Handset Logo
    19 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
