Question about Sharp AL 1631 Copier
Error code on display, L1 or 1L flashing. What is
Sharpe copy machine. AL-1631. Error code on display, L & 1 flashing seperatly. What is the problem?
  • 1,110 Answers
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Posted on Jul 16, 2010
  • Sharpcopier Sep 08, 2010
    thank you.
    The scanner was locked.
    I really appreciate not taking it to a repair place (which is physically difficult) to find out it was something we could have corrected ourselves.
SHARP COPY MACHINE AL 1631 FLASHES A L1 ERROR
Most likely when removing a copy someone hit the scan lock on the front of the machine.
Look on the front , bottom side of the scanner where the paper comes out. You will see a latch that is used for shipping the machine that is more than likely locked.
Thats what causes an L1 90 percent of the time. Just slide it to the unlocked position or take a small screw driver and remove it and throw it away. You can put a piece of tape over the opening to keep dust and moisture out
Jul 15, 2010 | Sharp AL 1631 Copier
Sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Nov 16, 2009 | Sharp AL 1631 Copier
My copier AL 1631 is showing an error in the display. it is flashing the number "1" and after the leter "L". Please help me
Turn off the on, if it doesnt clear do this; Check whether the scanner drive is locked or the copy lamp.
Oct 24, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
What is the code to reset the Sharp AL 1631 copier
Sharp - How to reset code
To enter service mode press thesekeys: orange C button,Interrupt, 0, Interrupt. The screen goes black when you have done itcorrectly. It may take a few tries – must be done in certain time.
To clear the maintenance indication (service man): press 20, start,1, start (the display will start to flash when entered correctly).Power off/on to make the copier dude go away. Good Luck!
Jan 31, 2009 | Sharp AL 1631 Copier
Error Code L
error L can not do anything We had power outage then this happened
Oct 13, 2008 | Sharp AL 1631 Copier
Flashing 4-H error message
try this reset procedure. Most likely this will work.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Nov 29, 2007 | Sharp AL 1631 Copier
fuser error - needs a tec - heater lamp, thermal fuse or thermister is broke. No simple fix
Oct 30, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
455 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
