Question about Microwave Ovens
KCMS135GBL0 Aren't these interlocking switches there to assure the door is closed, before the microwave is able to turn on??? Or do they actually actuate the latch itself?
  • Mapachi Apr 24, 2008
    My rhetorical question was in response to the person whom was suggesting I purchase a pair of switches to fix the door that is not opening by pushing the release button. Just by looking at the switches, seeing where they were positioned, and when they are actuated, I knew what they were for, but thanks for trying to help.
  • Microwave Ovens Master
  • 9,098 Answers
They are there to prevent it from running while the door is open.
The hooklike projections on the door go into the door switch mounts and latch the door closed, and at the same time they activate the switches.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 23, 2008
  • William Miller
    William Miller Apr 24, 2008
    Okay, here's the answer you really need then! :)
    You likely need a new "release lever". It's the part that the release button pushes against.
    If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
    Also at our Web site, we now have a video showing how to remove a typical control panel assembly in under 5 minutes.
    You can find helpful exploded view diagrams and order the part by entering your full model number here: http://tinyurl.com/gv383
    We're happy to help and we appreciate your thoughtful (revised) rating of our answer. *grin*
    William E. Miller, AS-EET
    prototech@usa.net
    http://www.microwavedisplay.com
Samsung microwave turns on when open door
The switch assembly is somehow staying "closed" satisfying the interlock and enabling it to run.
Disassemble the unit, beware specially of the high voltage capacitor, if you aren't comfortable or competent, buy a new microwave. If you are mechanically inclined, disassemble the unit until the switch assembly is accessible; it will have the door latch attached to it.
The switch is either broken or something? exogenous is keeping it closed. It may have come loose due to the door slamming?.
It's a simple fix. I am certainl you will be successful.
May 04, 2017 | Samsung Microwave Ovens
KItchenAid microwave KHMS1850S: interlock switches replaced, but fuse keeps blowing
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/khms1850s.html
Jan 27, 2015 | KitchenAid Microwave Ovens
Unit starts automatically when door is closed
please review this and fix it. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Nov 18, 2013 | GE PSA2200RBB Microwave Oven
Light stays on and turntable turns when door is closed and unit not in use.
see the diagram attached, and fix it. God bless you
  • Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  • Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replace
    Jul 08, 2013 | Magic Chef Microwave Ovens
    Magic chef model mco160s light stays on and the turn table turns when door is closed but unit is not in use. I think it's one of the door switches but I'm not sure and I don't have a part number. Unit...
    go to www. repairclinic.com and get it the parts. God bless you
    Jul 08, 2013 | Microwave Ovens
    I have to press up on the door to make it heat
    Rich,
    It sounds like there is an issue with the interlock latch or switch that allows the inverter to operate. Check the following:
    The door hinges to be sure they aren't loose, misaligned or bent.
    Check the latch on the door to be sure it engages the cam inside the main unit solidly and that there isn't any play in the door. Also check the door gasket to make sure it isn't preventing the door from closing properly. Since you said the unit was over the stove, things can become misaligned from the stovetop heat.
    You may be able to able to fix this, but it may require partial disassmebly of the microwave. If you are unfamiliar with this type of service, it's best left to a trained service tech.
    You should disconnect the power before attempting any repairs.
    Aug 18, 2012 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
    After shutting the door and starting the microwave oven a "popping" noise was heard and the microwave oven went dead. What do I do?
    I suspect your oven has a stuck interlock monitor switch. This is one of several switches inside that are operated by the door latches, and its contacts are supposed to open when you close the door. If the switch is stuck or is out of adjustment, it will cause the fuse to blow when you start the cook cycle. If there isn't any other cause for the fuse blowing, the switch can be adjusted or replaced as required. Microwaves are dangerous to work on, and door repairs can result in microwave leakage if they aren't done correctly. You should let a professional do the repair if you want to keep this oven.
    Apr 19, 2011 | GE Microwave Ovens
    The fan and light com on when the door is open and the carousel turns. When you close the door everything stops.
    Check the door interlock switches, you may have a faulty switch or a blown fuse inside the microwave.
    Dec 31, 2010 | Emerson Fans Emerson MW8115SS Microwave...
    GE Advantium Microwave section doesn't work.
    The primary interlock switch on my Advantium has failed twice. The replacement part is available at: appliancepartspros.com part no. for my Advantium was AP2622452 and it cost $11.74 + $6.95 shipping.
    For what it's worth, my nylon connector and wire covering were also scorched a bit but the last primary interlock switch lasted me for over a year.
    Please note that I am not an expert at repairing appliances and that I assume no responsibility or liability for any attempt you may make to repair your own appliance.
    May 30, 2009 | GE Advantium SCA2000B Microwave Oven
    Turns on when door opened
    this is dangerous; replace or adjust your door switches the interlock switches should only allow you to turn on the microwave when the door is closed
    May 29, 2009 | Jenn-Air JMC8100 Microwave Oven
    Microwave Ovens Logo
    50 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
