Question about Sharp AL 1631 Copier
SHARP COPY MACHINE AL 1631 FLASHES A L1 ERROR
The copy machine flashes a L then flashes a 1 what does the mean and how is it fixed?
    President:
  • 2,072 Answers
Most likely when removing a copy someone hit the scan lock on the front of the machine.
Look on the front , bottom side of the scanner where the paper comes out. You will see a latch that is used for shipping the machine that is more than likely locked.
Thats what causes an L1 90 percent of the time. Just slide it to the unlocked position or take a small screw driver and remove it and throw it away. You can put a piece of tape over the opening to keep dust and moisture out
Posted on Jul 16, 2010
Testimonial: "Thank you that helped a great deal."
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
I have an l1 error, and i have cleaned and sprayed wd 40 on the rail, problem remains, any suggestions?
L1 mean scanner not home position or copy lamp area is dirty.Clean all surface by soft cloth. Assembling again all cover and body.Power on may be fix your problem.Its a practical Idea.
Feb 09, 2011 | Sharp AL 1631 Copier
ESTÁ DANDO MENSAGEM DE ERRO L1 NA COPIADORA AL-1631
L1 signal means your copier exproser lamp carraige is not home position.Clean all surface and sensor hten solve it
with the best luck
Aug 03, 2010 | Sharp AL 1631 Copier
Error code on display, L1 or 1L flashing. What is
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Jul 15, 2010 | Sharp AL 1631 Copier
Error Message
You have a bad Laser Unit
Jun 02, 2010 | Sharp AL 1631 Copier
I have a sharp al-1631 flashing l1 code what is this and how do i fix it.
your scan unit cannot move. check if you use longer screw for top glass
May 24, 2010 | Sharp AL 1631 Copier
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
What is the code to reset the Sharp AL 1631 copier
Sharp - How to reset code
To enter service mode press thesekeys: orange C button,Interrupt, 0, Interrupt. The screen goes black when you have done itcorrectly. It may take a few tries – must be done in certain time.
To clear the maintenance indication (service man): press 20, start,1, start (the display will start to flash when entered correctly).Power off/on to make the copier dude go away. Good Luck!
Jan 31, 2009 | Sharp AL 1631 Copier
Flashing L1 Display
clean the stripe band unther the glass
Dec 26, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
324 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
