Question about Porter Cable Tools & Hardware - Others
Broken spindle lock pin on porter cable 893 router
Is it necessary to disassemble the motor to effect this repair?
3 Suggested Answers
mtatham
  • 13 Answers
SOURCE: how do I disassemble a porter cable 1002 router
How do I hold the armature still on a Porter Cable Model 1002 Router to take the nut off to change the inner bearing
Posted on Oct 13, 2009
rowdy45176
  • 2176 Answers
SOURCE: porter cable 7310 has broken
you would have to remove the bottom section of the motor housing. this would require removing the collet nut and the screws holding the housing in place. I would suggest going to "dewaltservicenet.com" and downloading a breakdown before attempting. It is not really that hard if you are mechanically inclined. The pin is more than likely jammed into the armature shaft that locks and that is why the motor won't turn. Let me know if you need more assistance.
Posted on Feb 21, 2011
How do u put on a saw blade for a cordless circular saw.???
First remove the battery, next make sure of the blade rotation and remove the hex bolt and OUTER flange lift the guard and put the blade on the spindle. Reinstall the outer flange and tighten the hex bolt, generally newer saws have a spindle lock to hold spindle to tighten the blade. If this is a Porter Cable like in the header you can go to dewaltservicenet.com and with your model and type number find an operators manual. Let me know if you need more assistance.
Mar 11, 2012 | Porter Cable Saws
Porter cable 7310 has broken spindle lock. THis is a brand new router and the spindle lock pin is broken and the motor will not spin. what is the best way to fix this
Feb 20, 2011 | Porter Cable 7310 Laminate Trimmer
Want to replace broken locking pin
It appears that the retainer is removed from the outside, Go to Dewaltservicenet.com and under manuals type in your model number I used 890 and you can download a breakdown for this tool. Did you remove the motor from the base so you can see it more clearly, the retainer might be an E clip that slides off with a pair of needle nose pliers.
Oct 17, 2009 | Porter Cable 8901 Router
How do you remove collet from porter cable router model 690 I have purchace a new 690 to mount to a mortise lock base and need to remove collet, the shaft threads onto the router where the collet is,
I would suggest going to Dewaltservicenet.com and typing in your model number for an owners manual for this tool. If you still need more help let me know and I will try.
Oct 01, 2009 | Porter Cable 690LR Router
Rowdy45176: the pin i am talking about is the pin that locks the shaft so you can change bits. i have mounted the router in a table and without the lock on the shaft i have to get under the table and...
OK looked at a breakdown with 400 mag, and it looks like the pin is held in place by a long lever that goes down the side of the motor, that lever has a cover over it with 2 screws to hold it in place. Look at the side and see if it if what I am describing and then the pin has a piece over it and a spring to push it away from the shaft. Let me know if this is not correct and I will call Porter Cable for you and get them involved
Feb 24, 2009 | Porter Cable 8901 Router
I have a 890 porter cable router and i need to know how to change the locking pin. i have purchased a new pin but i don't know how it comes apart.
I'm not sure exactly what you're referring to, but here's an exploded view of the parts for your router that may help you to figure it out more easily. There's also a user manual here, in case that will help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Feb 23, 2009 | Porter Cable 8901 Router
Replacing shaft on tiger saw
If the spindle is broken you have to take the front of the saw apart, but check for excessive wear in the other parts before buying just the one. Its not that hard just pay attention when you disassemble
Nov 30, 2008 | Porter Cable Variable Speed Quik Change...
How do I disassemble a porter cable 1002 router? I am trying to get to the motor in order to clean out pieces of broken brushes.
Oct 14, 2008 | Porter Cable Tools & Hardware - Others
Tools & Hardware - Others Logo
96 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
