Question about NetGear RangeMax NEXT WNR834B Wireless Router
IP address I have the netgear rangemax WNR834B and I looking for the ip address.
  • moonfire Jun 03, 2008
    can't access the ip address.  i have a macintosh G5
  • Anonymous Jul 14, 2008
    ip address
    Guru:
  • 1,342 Answers
Go to start, run and type cmd, click OK. When the black dos box opens up type ipconfig, the default gateway will be your routers ip address.
Posted on Apr 23, 2008
Tp link tl-wr740n how to install without cd
simply, connect it via network cable (LAN socket), turn on, check your gateway ip address, then type it in web browser, name/password should be admin/1234 or admin/admin, inside set what you need...
Apr 25, 2014 | NetGear RangeMax NEXT WNR834B Wireless...
Need netgear security key
Connect the computer to the router.
Check the IP address of the router.
Open the setup page and you will find the network key.
See how to find network key
Mar 31, 2012 | NetGear RangeMax NEXT WNR834B Wireless...
Need to know username and password
If you forgot your router password,you will have to reset the router back to factory defaults and log in using the default password.-->
To restore the factory default configuration settings without knowing the login password or IP
address, you must use the Default Reset button on the rear panel of the router.
Connect to the wireless router by typing http://www.routerlogin.net or the router's LAN IP
address (default is 192.168.1.1) in the address field of your browser and then press Enter. A
login window opens:.
Enter admin for the router user name and your password (or the default, password).
For more details use the netgear instruction manual--->HERE!
Jan 03, 2011 | NetGear WNR834B RangeMax NEXT Wireless-N...
How do I program the wireless router to my computer if I lost the disc?
Hello;
You connect a Computer via Ethernet to the router. Then, in the browser enter the ip address of the router. To get it you have to:
  1. Click START'RUN
  2. Type cmd and hit enter.
  3. type ipconfig and copy the default gateway address
  4. Go to the browser and type the IP address into.
Once there, on the management page of the router, you can configure what you need.
Nov 26, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
How to turn Netgear WNR834B into a repeater
I don't think the Netgear WNR834B is capable of acting as a repeater but there is another solution. I would decide where I want to put the Netgear WNR834B for best coverage and then do the following. Go buy the Powerline Ethernet Adapters of your choice and put one at the main connection and plug a ethernet cable into a open switch port. Second go to where the repeater is to be located and plug the 2nd Powerline Ethernet Adapters in and connect to the Netgear WNR834B LAN port. Be sure to turn off DHCP on the Netgear WNR834B and assign a IP address that is not used. I normally use the highest address in the last octet so that I can remember for management. xxx.xxx.xxx.254. I hope this helps you.
Apr 28, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Epson SX515 will not work wirelessly with Netgear WNR 834b v2
This printer cannot assign ip's to the router only the router is able to assign.
Apr 20, 2010 | NetGear WNR834B RangeMax NEXT Wireless-N...
Netgear unsecured
Log onto the router page by using the IP address in to the browser. To get that Open the Command prompt. To do that . Click start and in the run box type cmd. Or in the start search type cmd and right click and click on run as admin.
Then type ipconfig. Then the default gateway will denote the IP Adress of Router. Put that into the Browser and open the security settings and choose the encryption type and the password.
Mar 08, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
How to reset Netgear RangeMax NExT Wireless Router WNR834B
Do a hard reset (20sec hold reset button, unplug for 20 sec still pressing the reset button and another 20 sec to turn on the power while holding the reset button). That should reset to defaults.
Jul 04, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Trying to switch routers, can't get into new Netgear to configure
To configure it you can simply contect a pc to one of its rj45 port. it will give the pc an ip address in a default range. but the must have its network connection configured to receive ip automatically.
See the status of the pc LAN connection and note the gateway ip address. then type this ip in your explore address bar to access the configuration page / program of the router.
Hope that help.
Mar 16, 2009 | NetGear RangeMax WPN824 Wireless Router...
Problems with my new WNR834B
try to customize your wireless settings. change the wireless name/ssid to something else and change the wireless channel as well. verify also if there's a wireless security enabled, if it has you need to use the correct wireless security/network key when connecting your laptop wirelessly. you can go to the router's setup page to verify your wireless settings by typing the ip address of your router to the address bar of your web browser, http://192.168.1.1 (note: by default the ip address of the router is 192.168.1.1 unless you have changed it to something else. the default username is "admin" and the default password is "password")
hope this'll help you
ciao!
Aug 21, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
77 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
