Question about HP LaserJet P1505n Printer
Very light print out of hp p1505 laser printer is cery light even after changing tonner and cleaning scaning unit.
  • 223 Answers
This could be color miss registry, even though your printer is a monochrome printer there is a sensor which determines the color density, Black being a color, and if the sensor is damaged will cause issues like fading. Make sure you are using hp original cartridges, and if the problem is still there, contact hp for warranty options, hp's tech support line is 1800-334-51440.
Al
Eliteprintersolutions@gmail.com
Posted on Jul 15, 2010
Sir Iam Using HP 1007p Printer, One time i get the print in my printer, but my computer monitor "Engine scaning Error" window will be dipalyed, Pls sloved this problem in online
Laser scanner assm faulty, replace it..
If you are teck guy, open laser scanning unit check the engine motor rotation is it free or hard, lubricate it & clean the reflected glass.. fix it back and try..
Sep 20, 2011 | HP LASERJET P1005 Printer
My laser printer taking page but i cant find any output after printing finish.
did you check up the tonner status
tonner may be finish
Change the tonner / re-fill
May 30, 2011 | HP LaserJet 1020 Printer
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
My kyocera fs mita 1920 some dose not print or the message of add tonner come out while tonner was their why it do that?
remove the toner ... shake it well and re fix it and check ..... remove the drum unit and clean it ........ for more details please post your comment
Dec 29, 2009 | Kyocera Mita FS-1920 Laser Printer
Priner problem
This is likely to be a dirty lens on the laser unit in the base of the printer.
Dec 19, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Brother HL1250 won't print multiple pages
there are two reason behind the problem. 1.drum & 2.Fuser unit.
solution no 1.
In this printer the dram attache with the tonner. at first separate the dram unit from tonner. open the drum and clean the OPC carefully and also clean the blade. and re-assemble the tonner & drum. i think it will work for u.
solution no 2.
change the fuser unit.
Dec 01, 2008 | Brother HL 1250 Laser Printer
Magenta print out very light
This is caused by dust in the scanner assembly. There's a fan right by the magenta laser scanner that blows dust and particulate matter in the air directly on that laser scanner.
Requiring its removal and careful cleaning of all lenses and mirrors. Unfortunately, this is not covered in the service manual. Getting the laser/scanner out is not too bad: Start by removing the printer covers, the rear plate, and the plate on which the DC controller and formatter mount. Remove the four laser/scanner unit corner screws and the single screw for its cover. Be careful to remove the small shutter spring on the cover before removing the cover. Use a strong flashlight to carefully examine the copper-colored mirrors for dust. Use dry cotton swabs to carefully clean all dust from the mirrors and the lenses. Blow dirt and dust from the inside of the scanner box. You will notice that the bottom mirror, facing up, is the one with the most dust.
Jul 23, 2008 | HP Color LaserJet 2600n Printer
Black Lines and Very Harsh noise on a new Tonner. No printing with New tonner
Those printer tonners are very tricky to refill and a bad refill induse on bad printing so you can clean the drum (the round green thing) with isopropilic alchool. If it continues it indicates that the blade ( inside tonner plastic blade that cleans the excess tonner powder) is durty and you can clean it too with the same alchool. If it continues replace the tonner cartridge.
Feb 12, 2008 | Samsung ML 1710 Laser Printer
HP LaserJet P1505n Printer Logo
820 people viewed this question
Seeker5211
Seeker5211
