Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
During tank refilling
Lost power during a refill procedure now has scale error unit disabled.
what do you do?
    President:
  • 180 Answers
With switch on press YES/ENTER & STOP/NO key at the same time and watch the screen to come back as normal condition. If it is the same then you have to replace SCALE assy.
After replacing SCALE assy.you must CALIBRATE the new scal before use the machine. For calibration follow as bellow:
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key. now follow the on screen text.
NOTE:you should have 9KG/20LBS of weight for scale calibra
Hope this will solve your problem & if my solution is useful to you please vote for it.
Posted on Jul 16, 2010
My humidifier is spitting water plus steam. Kind of weird. Didnt do before. Level of water is ok, added 1 flat tablespoon of sea salt and 2 tabkespoons of vick oil. What's happening?
More than likely, mineral scale has built up inside the tank and the mist tubing.
To clean it, turn the unit OFF & unplug it. Empty any remaining solution that's in the tank and refill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Plug the unit in and turn it ON. Allow it to run for 5 minutes, then turn unit OFF and allow it to soak for 30 minutes to and hour.
Then turn the unit back ON. If the water spitting has stopped, run the unit unit is half empty. Turn it OFF, unplug it and empty any of the remaining solution. Refill with Bottled Distilled Water and run it until it's empty. Doing so, will flush out any of the remaining solution and scale.
In the future, it is best to use Bottled Distilled Water, rather than tap water. As the Distilled Water does not contain any harmful minerals or chemicals.
Hope this helped you and thanks for choosing FixYa.
Sep 15, 2011 | Vicks V150SG 1 Gallon Humidifier
Canon PIXMA MP 500 ink refills stop working
you have to reset the ink cartridge.. you have to use a ink refill reseter which come along when you buy a refill kit..
thank you.
May 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Tip
Epson Stylus Pro 3880
ERROR CODES CAUSES AND SOLUTION
1101
CR life error The CR scan path counter has reached a predetermined level.
(The end of life of the Ink Supply Tube)
Replace the Ink Supply Tube (INK, SYSTEM, ASSY) and reset the counter using the Adjustment Program. In addition, check the statuses of the CR motor (MOTOR ASSY.,
CR), the driven pulley, the Carriage Unit, and the Head FFC, if any abnormal noise or wear is found, replace the corresponding part(s) along with the Ink Supply Tube.1120
CR lock error The CR encoder failed to read the CR scale during a predetermined time period. Replace the CR encoder (BOARD ASSY., ENCODER, CR).
Replace the CR scale (SCALE, CR).The carriage unit does not operate due to a CR motor failure or some reasons. Move the carriage unit manually to check if it moves smoothly, and fix any abnormality.
Replace the CR motor (MOTOR ASSY., CR).1121
CR reverse error An abnormal operation (reveres movement) of the carriage was detected a predetermined number of times. Check the CR scale (SCALE, CR) for incorrect attachment, scratch, dirt, and fix any abnormality. Replace the CR scale (SCALE, CR).Replace the CR encoder (BOARD ASSY., ENCODER, CR).
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Feb 23, 2016 | Epson Stylus Pro 3880 InkJet Plotter...
Tip
Canon Pixma MX320 - How To Disable Ink Cartridge Error Detection..
How to fix the printing problem when Canon PIXMA MX320 series detected the errors in your cartridge?
I have a canon Pixma328 and have been refilling ink for black and color cartridges for quite sometime now. The cartridges are close but after I drilled a small hole on the top part of the cartridge using a small screw, there I find a way to refill the ink that I bought from an ink refill store. The procedure needs extra care, not to touch the contact point (copper) because its sensitive and not to damage the inner part of the cartridge when I insert the needles of the syringe used for transferring ink.
After refilling the cartridge, the next thing to do is to reset the cartridge. This will clear your printer from displaying common printer errors like U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
You can print as long as you want, refill the ink as long as you want and save a lot of money from buying a genuine canon cartridge by just following this simple tips for Canon Pixma MX320 and/or Canon Pixma MX328 all-in-one printer
For those who have replaced their ink cartridge before try to use that again and do follow this tip to make that work again.
on Jun 29, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Error 2 . How can we solve this problem. Thank you, Margaret
I found this procedure which was given by Taran_2005. I just come to try him(it) on mine, that works.
"The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero's or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away."
Sep 10, 2011 | Terraillon FBC Alteo Family Body Control...
Rinsed my humidifier with water and wiped the base down, refilled it and now it seems to be making the mist in the base butbisnt making it's way out of the mouth of the dolphin
The tubing to the mouth of the dolphin or the misting nozzle is clogged with mineral buildup and scale.
To clean this, do the following.
Empty the water in the tank and replace it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow the unit to sit for 30 minutes, then turn it ON. If mist does not appear within 10 minutes from the mouth of the dolphin. Turn the unit OFF and allow it to soak over night. In the morning, turn the unit ON and allow it to run. Once the mist appears where it should, run the unit until the tank is half empty. Then empty the tank of the remaining solution and refill with Bottled Distilled Water and run the unit until it is empty. This will flush all the remaining solution from the tank, tubing & nozzle.
In the future I would recommend using Bottled Distilled Water on a regular basis, rather than tap water. Doing so, will eliminate the problem of scaling.
Sep 07, 2011 | NewAir AU-200E Humidifier
Tip
How to fix a refill valve
  • Brass-style toilet refill valves can often be repaired. To take a valve apart, remove the lever's screws. This allows you to lift out the float arm and valve plunger. Check the flat rubber washer on the end of the plunger. If it's worn, you can pull it out with pliers and either turn it around or replace it. This procedure usually corrects an overfilling problem. Next, reassemble the valve. If the tank continues to overfill, check to make sure the operating lever at the end of the float arm is functioning properly.
  • New refill valve. To replace the entire refill valve assembly, first turn off the water supply. The tank should then be flushed and sponged out, as detailed previously. Remove the inlet nut and riser tube from the bottom of the refill valve beneath the tank. Hold the refill valve inside the tank with a padded locking plier/wrench to keep it from turning, and remove the nut beneath the tank. With the nut off, the refill valve assembly can be lifted out and a new one inserted in its place. Follow the exact instructions included with the unit you purchase.
  • Finally, reconnect the riser tube and turn the water on. The tank should fill, allowing you to adjust the water level according to the instructions that were included with the valve.
  • Anti-siphon valves. The best refill valves offer anti-siphon protection. In fact, this may be a requirement. This protection prevents back siphonage of toilet tank water into your home's potable water supply system if a vacuum occurs in the toilet's water supply system. Whether or not this is a code requirement, the anti-siphon valve is a good idea to protect your family and public health.
on Jan 16, 2010 | Plumbing
After flushing the toilet with the fluidmaster 300 installed, and during the tank refill, the refill valve emits an extremely high pitched squeal until just a second or two prior to the tank being...
hiya:) This is a result of a very minor design error (i am a big fan of FluidMaster products) combined w/a slightly higher than normal water pressure situation or foreign matter stuck in the valve somewhere. try turning down the water pressure via the shuttoff under the toilet tank:)
Jul 26, 2011 | Home
Error 6502
Dear Asker
how would i know this error is for which printer so i am assuming it's cannon.
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
Feb 28, 2011 | Office Equipment & Supplies
After brewing, unit occasionally fails to refill tank and shuts self off. Usually if unit is turned back on, it will refill.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 19, 2010 | Keurig B70 Coffee Maker
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
400 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
