Question about Roper REX4634KQ Electric Dryer
The heating element turns off after about 2 mins
It's been taking about 5 times to dry a load of clothes . So I took the load out of the dryer put it on max heat pushed the button , and watched for the heating element . It turned on after about 30 seconds then turned back off 60 seconds after that and never came back on . I've tripped the breaker and took the back off and made sure there where no loose wires . I couldn't find anything and it's still doing the same thing . Do you have anymore solutions ?
  • 550 Answers
The most common cause for thermostat problems is lint build up. in the exhaoust duct, in the vent hood on the outside wall, in the squirrel cage fan
there is not enough air moving past the heater element to keep it within normal operating ranges, the thermostat cuts it out.
when the reduced air flow cools the element below max, it cuts in, overheats the thermostat and cuts out, for the whole timer cycle.
clear the exhaoust ducting, fan and vent hood of all lint
and try again
If there is too much overheating a firesafe device thermal cutout will trip and does not reset
locate the thermal cutout, a small device that looks like this the heating element turns off after about 2 mins - 39ec5e4.jpg or this 9756eee.jpg screwed to the exhaust duct or fan housing. not resettable, test with ohmmmeter or battery and bulb,
the local parts guy will have the part, there are only a few for all the different dryer models
probably 75% chance of fix
Posted on Sep 06, 2008
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
WHIRLPOOL LER6620PTO DRYER TAKES MORE THAT 40 MIN. TO DRY A LOAD OF CLOTHES. WAY TOO LONG
Hi, you are correct. this drying time is quite long. i recommend checking the following areas on your unit to combat this issue. the most common issue here will be a clogged vent hose or blower housing obstruction.
Check the following---
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 17, 2009 | Whirlpool LER4634J Electric Dryer
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Dryer taking longer to dry clothes
For a gas dryer:
Assuming the dryer is working properly and the control cycles are ok, look for things like a restricted venting system which inclides the exhaust, lint screen, etc. This would be the large pipe connected to the dryer exhaust that vents outside.
If it's an electric dryer, there could be issues with heating elements, thermostats, a control board, the timer, etc. Also check for any excessive lint build-up.
Apr 12, 2009 | Dryers
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Heating problem with stackable washer/dryer combo
check the duct work going out of the house if it is clogged the clothes wont dry. Birds love to build nest in a open dryer vent and if you have any bends lint will build up get these clean and it should get you drying again
let me know what you find
bill
Jan 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Roper REX4634KQ Electric Dryer Logo
115 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Roper Dryer Expert? Answer questions, earn points and help others
