Question about Canon PowerShot A75 Digital Camera
Camera won't turn on - Canon PowerShot A75 Digital Camera
  • kakima Jul 15, 2010
    Okay, I realize this is a dumb question, but how are the batteries?
  • fredaugherty Jul 15, 2010
    I just replaced them. I even tried another set.
    Scholar:
  • 32 Answers
1. Most likely is discharged or improperly inserted batteries. Make sure to use freshly charged AA batteries that are inserted with the correct polarity. The Inner 2 have the minus side up and the outer 2 batteries have the + side facing up.
2. Close the battery door fully because the battery cover pushes on a small sensor that has to be closed before the camera will turn on. The battery cover slides and clicks into place. If the battery cover sensor is bent or damaged then the camera would not turn on. The battery cover sensor is tiny, and out of the way and probably not obvious that is has one.
3. Insert the proper memory card and close the memory card cover securely. If it's left open or not seated fully the camera may not turn on. I
4. Also remove the memory card and re-seat it, then close the cover again in case it was not fully closed.
5. Remove the batteries and check that the battery terminals are clean and they appear to be intact. For example, corrosion from leaking batteries could cause a poor connection.
6. Was the camera dropped? If it was dropped that can bend the metal battery contacts, then when you put the batteries in it doesn't really contact the battery properly.
7. If it still won't turn on have an electronics guy check it over, or at the local college electronics teacher. I've fixed these before and the main DC circuits are not too complicated. These camera's can even be powered up using a regulated 6V DC power supply connected properly to the battery terminals, (just for testing) and in that case you don't need batteries to tell that the camera works or not. These draw about 300mA of current when ran from 5V to 6V DC.
I attached a JPG photo showing a similar Canon A60 running via a DC power supply and no batteries. This one was apart at the time to fix a stuck zoom lens, and when it's apart there is no where to put the batteries so I have to power it this way.
You do not have to take it apart or use this method. I just mentioned this so it's clear that all it needs to run is 5 -6V DC from properly charged and inserted batteries (or an external source). Don't try connecting anything if you are not familiar with electronics because connecting it up wrong can damage the camera. Try the suggestions mentioned early and it will probably work since these are pretty reliable cameras.
Posted on Jul 17, 2010
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 29 Answers
CANON POWERSHOT A75 Battery
  • Original Brand : CANON
  • Original Model : POWERSHOT A75
  • Cell Type : Li-ion
  • Volts : USB:5V 700mA, DC:8.4V 700mA
  • Capacity : 4000mAh/14.8Wh
  • Average Run Time :2-4 hours(minimum)
  • Color : Black
  • Dimension : 51.90 x 38.40 x 14.20 mm
  • Net Weight : 38.50g
  • Condition : Brand New. Never refurbished.
  • High capacity, rechargeable Li-ion battery with premium cell.
  • Best replacement for the original CANON POWERSHOT A75 Battery pack.
  • CANON POWERSHOT A75 battery replacement :
    UK shop:
    http://www.global-battery.co.uk/digital-camera-batteries/canon-powershot-a75.htm
    US shop:
    http://www.sales-battery.com/digital-camera-batteries/canon-powershot-a75.htm
    Canon camera batteries:
    US : http://www.sales-battery.com/digital-camera-batteries/canon.htm
    UK : http://www.global-battery.co.uk/digital-camera-batteries/canon.htm
    Posted on Dec 09, 2010
    • 51 Answers
    Normal batteries it's not working for me!
    After i replace standard alkalines with rechargeable NiMH batteries Sony and Varta 2700 Ni-MH it's was working!
    My camera it's turn on every time!
    Posted on Jul 16, 2010
    Camera won t turn on
    What model Vivitar camera? What type(s) of batteries?
    Jun 20, 2013 | Vivitar Cameras
    Fujifilm xp30 that won't turn on.
    Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
    Dec 16, 2011 | FUJIFILM FinePix XP30 Digital Camera
    My Lumix DMC-LX5 camera won't turn on
    Nov 10, 2011 | Panasonic Lumix DMCLX5 Digital Camera
    Canon powershot SD1300 IS won't turn on, even with fully charged battery
    Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
    I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
    Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
    Aug 23, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
    My camera will not turn on even after charging it for a long time. The battery works in other cameras except mine so the battery is not the problem. Why will my camera not turn on?
    Aug 22, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
    My camera won't turn on and the lens won't close
    Perhaps you have bad batteries? Connect it to another power source such as an AC wall outlet and use your power adapter and see if this helps. If it does not or you have already tried this then your camera may need to be serviced.
    Jun 29, 2011 | Kodak Cameras
    Canon PowerShot A75 Digital Camera Logo
    350 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
