Determine nozzle size for a beckett oil burner model number af and serial number 000710 54688
  • 116 Answers
SOURCE: need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
Posted on May 15, 2009
  • 13 Answers
SOURCE: Honeywell Beckett Oil burner locked out.....just
is a single pipe oil line or a double pipe
Posted on Nov 04, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: my beckett oil burner
Hello
Depends on the temp your trying to keep in the house.Possible heat is running more then usual due to cold weather?
But to answer your question no the nozzle is made for the model of your burner so its almost im possible to install the wrong one.
What is possible is the air mixing with the fuel may not be set correctly,kind of like a carburetor running to rich or too much fuel not enough air.
There should be a sliding flap on the burner you can move open and close to adjust air/fuel mix.
Not recommended with out proper gu ages .MAy want to have then come back out to readjust.
Posted on Jan 12, 2011
  • 4736 Answers
SOURCE: i need to register my air conditioner but i cannot
The Model Number is usually 12 or more numbers. Hope this helped you pin it down. Thanks for choosing FixYa.
Posted on Aug 08, 2011
marla_pruitt
how do you reset a beckett oil burner when your locked out ?
Posted on Sep 19, 2012
How do you reset the type control/restart an older Beckett burner after oil ran out? Oil has been added and the lines bled. However the burner will not stay on after hitting reset
First,mop up the unspent oil in the combustion chamber from any previous relight tries. Now, make sure the cad cell lense is clear. Did you change your oil filter and nozzle? These become easily clogged by the sludge at the bottom of your tank when you run out of oil.
Mar 13, 2017 | Heating & Cooling
I have an oil burner that is leaking. how can i determine if it is oil pump or something else?
Do you see oil or water? If oil then the pump seal is broken and you need oil Tec to change the pump.
Dec 31, 2013 | Beckett A2EA6520 Single Stage Clean Cut...
My beckett oil burner is consuming way too much oil ,would it have anything to do with the nozzle, my oil men service it last year and im afraid maybe he put the wrong one, is it posible ,
Hello
Jan 12, 2011 | Heating & Cooling
I think the fuel pump on my beckett burner is clogged is there a way to clean it. Ive replaced the filters and get fuel to the burner but get no fuel up to the line feeding the nozzle
As you face the burner, mounted in the unit, the oil line feed in on the left side. There is a cap, held on by 4 7/16" bolts. Inder the cap, there is a screen. You would be best to get a screen kit, available from the same place you get your nozzle, as it will come with a new gasket.
Shut off the oil. Remove the four bolts, pull the old screen, clean the housing (I use rags and WD40) and re-asssemble. If is is really bad, you should remove the nozzle assembley and flush the oil line to the nozzle, as well.
THe oil filter, screen and nozzle should be replaced at least once a year.
Jul 06, 2010 | Heating & Cooling
How to set electrodes on a beckett burner AF 11
Call 1800 Oilburn and they will send you a gauge.
Apr 27, 2010 | Heating & Cooling
Dripping fuel from the bottom of the burner its a af15 beckett oil burner
No, you should call a person that can service oil burners. Either the nozzle is bad and oil is dripping into the burner tube and running down or the nozzle is loose and the oil is running out from the threads of the nozzle. Either way the nozzle should be changed and the burner retuned with a combustion analyser..
heatman101
Mar 27, 2010 | Heating & Cooling
Nov 04, 2009 | Heating & Cooling
Beckett burner; I notice small particles of soot under stack vent
The soot can be caused by a number of reasons, if it was recently cleaned, I would wonder if the service tech just left a little mess behind. If you are reasonablely sure that is not the case, one cause could be a faulty pump. Inside the fuel pump is a pressure regulating valve, that is responisible for pump pressure and cut off. If the valve is failing, and not giving proper cut off, then a small amount of oil will drip into the chamber (called "after drip") and upon start up this oil burns incompletely causing a soot build up. A delay valve often masks the problem by providing the positive shut off electronically. Another problem/cause could be impoper adj. of the burner during the tune-up. On a final note, with equipment that old, it would be a good idea to start looking into a newer, more efficient system.
Apr 10, 2009 | Leviton White Decora Oil Burner Rocker...
Heating & Cooling Logo
435 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
