Question about Motorola CLS 1410 (4 Channels) 2-Way Radio
Can not change code and frequency - Motorola CLS 1410 (4 Channels) 2-Way Radio
  • Motorola Master
  • 1,654 Answers
First, we would suggest resetting the radio to the factory default settings by turning the radio on while holding Push to Talk and Menu button for 3 seconds.
After doing this, check to see your radios function with one another. If they do, then proceed to programming the radio to the frequency/PL codes you are wanting. If the radios do not communicate after resetting them, one of the radios has a problem.
Here is a link to the user guide: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf You will find programming instructions on page 28, with a frequency chart located on page 26.
Best regards.
Posted on Jul 27, 2010
On motormu2080d, I finally got frequency changed. It still is not receiving or sending. What do I need to do?
This one is new for me, so if you posted elsewhere, bear with me. You changed the frequency, I assume to match another radio. Now you must also change the Tone, called PL, DPL,or CODE, etc. Both frequency and tone must be EXACT. Such as Frequency 2, code 1. which is default channel 1 on UHF radios. Also be certain you are not trying to match to an RMV radio, and RMV and RMU cannot talk to each other.
Apr 15, 2015 | Radio Communications
Cp150 frequency change
This is a programmable radio. Using Motorola proprietary software, programming cable and radio interface box (RIB) the radio can be reprogrammed to another frequency/PL Code. This can be done by your Motorola dealer.
Feb 12, 2014 | Motorola Radio Communications
How do you change the channel on the AXU4100
Here is a link to the user guide, where you will find the available built-in frequencies, and instructions: http://acsspirit.com/brochures/ax_user_guide.pdf
You can also take your radio to a Motorola dealer and have them program it (custom) using Motorola software and cable designed for this style radio.
It could be as simple as enabling a private line code (PL code) in the radio. You may not need/want to change frequencies. Adding a PL code would block out other users on your frequency. You would not hear them, despite them still being there.
Best regards.
Dec 19, 2012 | Motorola AXU4100 (10 Channels) 2-Way Radio
How do i change the frequency on a mototrola sp21 from 12.5khz to 25khz?
The SP21 is PTT programmable.
1) Hold in the PTT while turning on the radio. Let go when the female voice begins to speak. It will announce the frequency number. You can use the PTT to walk through the 35 to 40 frequencies available. Then when you have reached your desired frequency. Press the MONITOR button to lock it in. (small button on the PTT).
2) Then your radio will announce the PL code. Using the same method of pressing the PTT you can walk yourself through the 38 possible PL codes. Press the MONITOR button to lock in your preferred code.
To answer your question concerning 12.5k to 25k selection. You should at this point in time be changing to 12.5k (narrowband). All VHF and UHF users are required to move to narrowband by Jan. 2013.
In the VHF SP21 frequencies 1-16 are 25k, and 17-37 are 12.5k.
In the UHF SP21 frequencies 1-16 are 25k, and 17-40 are 12.5k.
Best regards.
Jul 24, 2012 | Motorola Radius Vhf Sp21 2 Way Radio...
I brought my phone from hawaii and i tried to service it but it cannot. the only thing that needs to change is the hawaii frequency or service to american samoa frequency service. So, how can i change the...
If the phone is tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Nov 01, 2011 | Palm Treo 700wx Smartphone
I have a motorola mv11c and it works fine and I just purchased a pair of motorola mv21cv. They must be on a different frequency my question is how do I change the frequence on my mv21cv radios to be...
Hold in the PTT button while you turn on the radio. It will announce the frequency number. You can use the PTT button to change the number. Then press the Monitor (small possibly red) button to lock in your setting. The next number your radio announces will be the Code. Use the same method to change the code if needed. Then press the Monitor button to lock in your setting. Once you have set both your freq and code you can turn the radio off, then turn back on normally and use the radios.
Best regards.
Jul 22, 2011 | Motorola MU21CV (1 Channel) 2-Way Radio
Police frequency code for the city of southgate, ca . i have a uniden police scanner however i can not seem to find the city codes. do you know where i might be able to find these codes?
For a comprehensive database of active frequencies in your area (they're no codes), visit:
www.RadioReference.com
There's a good chance that your community has changed from conventional frequency usage to a trunked radio system. If that's the case you can read up on it at RadioReference.com, but you won't be able to monitor the action with your current scanner.
BillB
Jan 25, 2010 | Uniden BC248CLT Base Scanner
Frequency changing
Here is a link to the manual http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf
Entering Programming Mode
Press and hold Push to Talk and Monitor for 3 seconds while turning the radio on. The
radio beeps and displays PROG, the channel number flashes, and the frequency
(indicated by FREQ) and code (indicated by CODE) display alternately.
Use the MENU and the + or - keys to change the programming. More detailed instructions are on page 28 of the manual.
Best regards.
Dec 29, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Tk-3100
Hi Tucaraca.
With the radio OFF, switch to CHANNEL 1, press the SQUELCH and the PTT at the same time. Turn ON the power switch while keeping the PTT and SQUELCH until the LED indicator turns RED.
Release the buttons and then press the PTT to CHANGE the FREQUENCY.
Press the PTT once each time until you get to the right frequency you desire. The 8 standard frequencies are as follows: 464.500, 464.5500, 467.7625, 467.8125, 467.8500, 467.8750,467.9000 and 467.9250 MHz. Once you get to the frequency you use, wait a few seconds and listen for the confirmation tone. Each frequency has a different confirmation tone so take note in case you need to program a second radio.
After you hear the confirmation tone, press the SQUELCH to confirm, and then press the SQUELCH again to lock the new frequency. Wait until the LED turns off, then switch off your radio.
Same procedure for CHANNEL 2.
WARNING: You must be legally licensed to use any frequency on any PLMRS such as the TK-3100 series. You must also apply for FREQUENCY COORDINATION and submit FCC form 601. FCC can impose steep fines and imprisonment if they catch anyone using an unlicensed radio on a controlled frequency. Visit FCC.GOV for more information.
Nov 27, 2007 | Kenwood TK-3100K2 (2 Channels) 2-Way Radio
Motorola CLS 1410 (4 Channels) 2-Way Radio Logo
471 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
